Thread: I'm about give up on a pool how do you get fine sediment out
    I bought an intex pipe type pool not the blow up kind I have had nothing but headaches from getting the pool even I.
    Which we had to drain all the water twice and to even the dirt out then with filling the water the third time I used my well water
    the first two time I had it filled by the fire dept but it was a hundred dollars each time.
    Next after adding my chlorine the water turned brown from iron
    that was another couple weeks of working on the pool
    finally got the brown out and aftermay and June having never even stepping into the pool
    it was time I got sunburned my own fault
    then my 12yr old daughter and her two cousins went in andmplayed all day in there
    it was great but they kept running in and out dropping there glories on the ground with them
    All dirty they would bring them in the pool
    now I have a ton of dirt that if I vacuum with the hose type vacuum I'm going to put iron back in the pool and the intex says not to hook a vacuum to the filter
    so I bought a battery operated vacuum which it says on the box will pick up fine dirt and silt
    wrong it blows it right out so I had to buy a special filter for it and a piece of sticking type material
    tried that and it blew the dirt right out again
    I do not know what I can do
    my daughter and I have been in it once each and I'm losing patience
    I'm really hating this pleas help
    also does anyone know why you can't run the intex filter when people are in the pool thanks
    Traci
    Edited for line breaks only. Butterfly
    Round intex 16 foot x 4 foot deep Eastern Pennsylvania just the basic crappy intex pump that comes with pool
    Re: I'm about give up on a pool how do you get fine sediment out
    Oh by the way the vacuum I bought was an aquabroom thanks again for any help
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You can't run the Intex filter while people are in the pool for safety reasons. The installations are usually performed by people without electrical training, and the pump probably hasn't been as well tested for safety as more permanent pools.
    Does the dirt get stirred up and mix with the water when people are swimming? If so, just spending time stirring it by brushing a couple of times a day can help the filter pick the dirt up.
    You aren't alone. The big weakness of those pools is the filtration system. There are some upgrade systems that can allow you to use a standard vacuum, but they can cost as much as or more than the pool itself.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    For your own sanity, I would consider upgrading to a better filter/pump that allows vacuming into the filter, for next year's season (I'm assuming you'll take this down for the winter?).
    If you do some research now, you may be able to find and end-of-season special and get a good price.
    A small 3/4 hp pump/sand filter combo may do the trick.
    So sorry you aren't enjoying your pool.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Not to venture away from the subject but, what are glories???
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    and for my sanity, for goodness sakes, please use some punctuation !
    25,000gal IG Vnyl pool/Challenger 1HP Pump/ Triton II Sand Filter/Denver, CO/ Complete Noob at pools and anything to do with them (besides swimming)
