Results 1 to 20 of 20
Thread: New test kit and new pool
    Kentucky
    69
    I got my test kit today and they are putting up my pool as we speak.. Here are my results from my tap water which is what we will use to fill my pool.. However, I am having about 2500 gal's of water shipped in so I don't know how much effect that will have on my test results... Anyway here they are and what would you recommend I should purchase at this point to add once the pool is filled.. (hopefully by friday)
    CC=0
    FC=1ppm
    TA=70
    CH=90
    PH=7.2
    Is there anything else I need to test for??
    Thanks for your help....
    When I test the CYA (didnt do yet) the directions say to fill the thingie to the bottom line is that the bottom line of the label and then the top line is the top of the label??
    I would guess I don't have any CYA so how much of that should I add when I fill the pool??
    Also, is there an order at which I should add chemicals to the pool?? ex.. bleach, cya or cya bleach..??
    1) 16500 gallons
    2) 150 lb sand filter
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: New test kit and new pool
    you need bleach/chlorine and cya. the cya will be 0. use www.thepoolcalculator.com to figure amounts.
    Kentucky
    69
    When do I need to add the other things other than the bleach and cya??
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    for a vinyl pool your other #'s look fine...bleach and CYA is all you need for now
    Kentucky
    69
    THANK YOU, THANK YOU!!!
    They are spreading out the liner now and getting ready to put that in I think..
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Kentucky
    69
    We measured what a 28' pool would look like but I guess I really had no real idea just how large that was... Its huge!!!
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Kentucky
    69
    According to the calculator
    I need to add
    115 oz of 6% bleach
    and
    256oz of CYA
    Does that look correct??
    Should I add this in any particular order? Should I wait any time before I add one after the other?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    what are you putting in for your numbers in the target and goal columns?
    Kentucky
    69
    Quote Originally Posted by reebok
    I left them at their default numbers
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    well, you want to shoot for a CYA level of 30ppm (so put in 0 and 30) and an fc level of about 4. (so put in 0 and 4).
    Kentucky
    69
    OK, so add
    153 oz of 6% liquid bleach
    192 oz of liquid cya
    Is that right?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    yes but liquid cya is about twice as expensive as granular.
    Kentucky
    69
    Great!!!
    Doesn't it take about a week for the granular cya to dissolve? Would it be better to just add the liquid even though it is more expensive? Also, do you need to add the CYA very often?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    it takes up to a week for it to register on a test. once it's in there, it's in there. so no it's not better. just wait a week to test to be on the safe side that you don't waste reagents. but once it's dissolved (however you choose to do that) you can assume your level is whatever you added (i.e. if you add the amount to reach 30ppm, assume it's now 30ppm and test in a week to confirm).
    cya is only lost to splash out, leaks, etc. (and possibly another rare situation) it is not lost to evaporation, so no you don't add it often. very rarely. the people who add it most are people who drain their pools completely over winter and refill in spring.
    Kentucky
    69
    Thank you!!
    You have been so helpful
    So, for now I don't need to add anything else like borax?? When should I expect to add those other things?
    Can I add bleach right after I add cya?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    it's the same, not worth the added expense IMHO. Once you add CYA granules, you can assume you have that level of CYA, you just cant test it for a week. You just put it in a sock over your return. Your main objective is to add FC to the water to hold off algae. CYA just slows the burn rate of the chlorine.
    CYA only get's dilute if your replacing water...ie lot's of rain and you have to dump water. You don't lose CYA due to evaporation. The only other time you can lose CYA is over the winter it sometimes has a tendency to dissappear through a chemical process I am too dumb to describe and converts to ammonia...but you don't have to worry about that right now
    Kentucky
    69
    When you say add the cya to a "sock" do you mean like panty hose or a real sock? lol
    If I used the granule CYA would it be 77oz then?
    If I used the liquid I would just dump it in like bleach right?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    either will do...plain old tube sock works just fine...just tie the end and hang it in front of your return...you'll see it wiggling around and keep your pump running until it disolves. You can mush it up from time to time to speed up the disolving
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by momof3
    74oz by weight. 77 by volume. if you get liquid follow the directions on the bottle.
  20. Back To Top    #20
    Kentucky
    69
    The installers just left now it's just a matter of waiting for it to fill up...
    I will go tonight to get the bleach and cya...
    Thank you for all your help.
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
