Thread: Letro Legend Pool cleaner
    Jul 2009
    Coppell, TX
    1
    I recently bought a house with a pool. I am a newbie to pools and pool maintenance. I recently noticed that the wall fitting on the pool cleaner had a crack in it. I went to the local pool supply store and bought a replacement made by polaris. When I install the polaris one, the pressure relief valve is open. I don't understand if the problem is with the polaris wall fitting or i have the wrong kind, or I did not install it correctly. Also, there are 2 (red and blue) discs that came with the polaris wall fitting and I have no idea what to do with them. Any help is much appreciated.
    Sanjay
    I have an approximately 18000 gallon pool with DE filter and is plastered IG pool
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    404
    Re: Letro Legend Pool cleaner
    One of the manuals on the Pressure Side section of this page (http://www.pentairpool.com/techinfo/dat ... hp?d=2&s=7) should explain how to use the discs. You use one of them (or none) to regulate pressure to the cleaner.
    When you say "the pressure relief valve is open" do you mean you can see that its open, or that water comes out of it when its on?
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
