Results 1 to 9 of 9
Thread: How long does the test kits last?
    Loogootee, IN
    122
    Hi Gang,
    I see a lot of reference to purchasing a Taylor K-2006 and the TF100. My question is, Will these test kits last longer than one pool season?
    The cheap 6 way HTH kit I purchase, says to dispose of it when the pool season is over. Only being able to swim roughly 3 1/2 months out of the year here in my neck of the woods, makes it hard for me to justify paying 65-75 dollars for a test kit.
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: How long does the test kits last?
    there are a few threads on this. here is one.
    reagent-life-t7255.html
    in the very bottom left of every page there is a google search that works better (usually) than the forum search in the top right of every page.
    30,415
    There are hundreds of folks here that would disagree. The money you save by testing accurately and not blindly buying "magic bullets" at the pool store (trying to get your pool balanced or rid yourself of an algae bloom) will pay for your test kit even if your swim season is two weeks.
    I am not telling you this because I sell test kits.....I am telling you from experience what my kit has done for me. Others will attest to the same experience.
    The TF100 should last a residential user at least 2 years with normal usage. There are some situations that can use up some of the reagents more quickly, but they are rare. Also, refills are less expensive than replacing the entire kit.
    How much the kit is worth depends on how much you spend a year on chemicals and how often things tend to go wrong. A top quality test kit can save you dramatic amounts of money on chemicals compared to a cheap kit. Some people save hundreds of dollars, others not so much. Of course this effect is more significant with a larger pool. Some very small pool owners won't spend enough on chemicals, even with problems, to make up the price difference.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by PachinkoPlayer
    Hi Gang,
    It's not just a reference, it's what is recommended
    Comparison articles are in Pool School FYI. And yes, the kits will last more than one season.
    From what I have read (&personal experience w/the TF100), most of us get at least two seasons and then some.
    Certain refills may be needed by some members if they run into a big problem.
    Depending on how the kit is stored/maintained, the cheap 6 way or any other kit may be ruined.
    The cheap 6 way kit would work pretty good for someone with a small pool. You are able to just drain and refill if you have big issues. In fact, duraleigh (who sells the TF100) does not recommend the TF100 for a pool your size. We are trying to get more info for folks with the smaller pools. : Have you seen this thread? simplifying-bbb-for-very-small-pools-e-g-intex-t14533.html?hilit=small%20pools
    BTW, the BEST investment we made in our pool is a good test kit. It is what puts pool owners in charge of their pools!
    You're done SLAMing when:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I agree...since we got our water balanced, our past months cost for chemicals was $0...now I am using a swg, but otherwise it would just be bleach. On our last pool, that made me vow to never own a pool again (my better half and TFP convinced me otherwise ) I was spending an avg of $140 a month in shock/algaecide/metal-out and hated the smell and feel of the water...just MHO
    The Kit pays for itself in the 1st month of ownership
    Loogootee, IN
    122
    eeek, um if I offended some of you folks, I certainly apologize! It wasn't my intention what so ever to down/dog your recommendations.
    I guess I shouldn't have put the comment about
    "Only being able to swim roughly 3 1/2 months out of the year here in my neck of the woods, makes it hard for me to justify paying 65-75 dollars for a test kit."
    Now that I have read it a few times, it does sorta sound kinda rude.
    I apologize and will proof read my posts more carefully in the future. And since I have read more about the T100 and the different tests that can be performed and can also get more than one season out of one of the better test kits and refills , I will definitely be purchasing one in the spring!
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    You can prolong the life of all the liquid reagents by making sure they are closed tight and storing them during the off season in the refrigerator above freezing temp.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Guest
    I live in Florida, have a test kit that is abo0ut 5 years old that still has good reagents. I store it in a cabinet in the spare bathroom. The only reagents with a short (2 year) shelf life are the FAS reagent and, if not stored correctly, the DPD powder. All the other reagents should last through several seasons. A good test kit is actually economical to use because there is no question as to what the results are (once you get the hang of testing. At first some people waste some reagents but you get the hang of it pretty quick.)
    The amount of money that you save in chemicals really does pay for the kit very quickly.
    The main difference you will see will be the first time you do an FAS-DPD chlorine test. You will know exactly what the resutls of both your FC and CC are without any questions since you are not trying to match shades of yellow to a comparator. Your HTH test can only test TC, btw, so it's not giving you the information that you really need.
