Results 1 to 7 of 7
Thread: DPD Powder
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    DPD Powder
    How can you tell when your DPD Powder is too old to use for testing?
    Master KomodoKamado griller & beer maker!!
    12,000 gallon in-ground, pebble-tec, SWG pool w/spa
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: DPD Powder
    I believe it starts turning dark/black.
    30,419
    Re: DPD Powder
    Nope. If it turns your pool water (with chlorine) pink or deep pink, it is still good.
    The only way you can tell that it's not working if it fails to turn the water pink and you know it has chlorine in it.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: DPD Powder
    whoops, sorry. I was basing my answer on this post post121354.html and this post reagent-life-t7255.html
    so if it's black it's ok?
    Re: DPD Powder
    The general wisdom has been to replace the DPD powder when it gets black. However, it has subsequently been discovered that it doesn't stop working completely, it just gets clumped up. If you break it apart enough to dissolve, it still gives correct results.
    Of course, Taylor says to replace all reagents each year.
    Guest
    Re: DPD Powder
    Black DPD powder has been oxidized so it's ability to form the red Wurster dye that we subsequently titrate with FAS titrant (a reducing agent that is also ruined by oxidation and changes pinkish to orange when bad).
    IF the DPD powder is not completely black then it is still usable.
    FWIW, I have seen DPD powder that was completely black but not clumped at all and clumped powder that was light gray. Clumping is a function of humidity, turning black is oxidation (exposure to atmospheric oxygen).
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    Re: DPD Powder
    My powder is gray and turns pink quickly when added to the water sample...so I guess I'm OK. Thanks!
