Thread: Sand Filter Maintenance
    Split from sand-filter-maintenance-t12275.html Butterfly
    New pool owner and I was told that the sand in my filter has to be changed out about every 5 years. From the answer below it was stated that sand only has to be checked from time to time to make sure it is not crusted over, loose and level. Unfortunately I am not home right now and cannot tell you what make of filter it is. Pool service wants to charge me $350 to change out sand, if it doesn't need to be done I could sure use that money elsewhere.
    Carol
    gunite pool
    15,000 gal
    Intex 12x20 4300 gallon vinyl
    Intex 4000 gph cartridge filter "B" pump
    TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Sand Filter Maintenance
    Unless you have used chemicals in the past like Baquacil, you probably don't need the sand changed. $350 to change the sand???
    Guest
    Did they give you a reason why they said the sand need to be changed? Personally, I am of the camp that does believe that sand does need to get changed out about every 7 years or so because it gets worn smooth because of erosion and doesn't filter as well but you can use DE as a filter aid to increase the filtering ability of old sand. If the sand is channeled that can be easily fixed. If the sand is calcified that may or may not be fixable by an acid wash.
    My suggestion would be to look at the sand yourself and then try washing it and see.
    my-sand-is-channeled-how-to-fix-it-t7626.html
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    $350 to change the sand is WAY too much. I had my sand changed and I was charged $125.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
