Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 110
Thread: Diary of a swamp
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Diary of a swamp
    I hope my topic is not improper since it is more of a diary of my steps of going from swamp to pool as opposed to a question. I was wanting a synopsis of what I did to correct my problem for posterity. However, I would love any comments if it seems I've gone astray or on the right path.
    Background:
    After trying to open for the season I noticed a couple small leaks, but mostly had to constantly backwash which made it difficult to balance and clean so I decided to upgrade. I had basically replaced all my equipment with new equipment/plumbing. Replaced SuperPump II with WhisperFlo dual speed and 48 sqft DE filter with S310S sand filter with 6 multiport valve. The only thing I didn't replace is the heater which I had replaced last year.
    Including this link for reference:
    http://www.troublefreepool.com/turni...0green%20swamp
    21k gal, plaster IG pool with spa
    Main - 1 skimmer, 1 main drain, 3 returns, Spa - 1 drain, 4 returns
    WhisperFlo Dual Speed WFDS 1.5 HP pump
    S310S 30" sand filter
    Polaris 360 pressure cleaner
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Re: Diary of a swamp
    Day 1 (7/5/09):
    I completed the installation and started up. Noted leak at pumps output threaded connector . It seems I failed to tighten it enough so I caulk it with silicon caulk as well as all other connections for extra sealing.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Day 2 (7/6/09):
    3:45pm - Started system up again after caulk set, realized that I missed a spot on the leaking connector . Leak is minor enough to ignore at the moment but at some point will probably need to replace connector. Tested PH = > 8.4. Added about 40oz. Muratic Acid in front of deep end return.
    4:30pm - Tested CYA ~ 0. Filled sock with conditioner and placed it in the skimmer. Removed cover from pool.
    7:30pm - Retested PH ~ 7.6, Added about 8 oz. Muratic Acid into spa.
    9:00pm - Retested PH ~ 7.3 . Tested Alkalinity = 50, Added 10 lbs Baking Soda into skimmer. Switched pump to low speed.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Day 3(7/7/09):
    6:00am - Ph = 7.5, TA = 80, Calcium = 330
    5:00pm - Added more stabilizer to sock to bring the total to about 5 lbs.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you don't mention the one ingredient to clear a swamp in here at all. did you have a swamp?
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    I assume you are referring to the chlorine level which is 0. No chlorine had been added since I closed the pool last October, nor had any real action been taken except for what I described. Until I get the CYA up to a decent level I don't think it would benefit anything. Hopefully the CYA will be up in a day or two.
    I'm not sure what your asking, but it seems like a swamp. Pool is a dark green and several tadpoles were sucked into the pump when I started it.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    oh sorry, I thought this was a past tense thing (you cleared your pool already and wanted a log of what you already did to clear it up).
    if your cya has dissolved it's good to go so start shocking. but don't test for cya for a week (it's in there it just may not show up on a test so don't waste reagent).
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Yes this is an ongoing thing. I just started dissolving the stablizer yesterday. I updated my day 3 post to indicate that I added more stabilizer to the sock which should be about the 5lbs I need. Thanks for the CYA tip. I did not know not to test it for a week. Do you know why the CYA doesn't show up for a week?
    CYA takes several days to dissolve, sometimes up to a week.
    You need to get chlorine in your pool. Use the CYA chlorine chart in my signature, and shock to the level of CYA that you should reach after it all dissolves.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    something about it's not all dissolved I think. it may show up sooner, it may not, so it's recommended to wait a week so you don't waste reagent testing something that may not show up even though it's really there. the other issue is high cya is a big problem, so if you test the next day and see 0 cya, you add more, so on and so forth and end up with way too much cya. pool-school/ should have all the info you need to clear up your pool, but ask about any questions or problems you have. good luck, it will work if you stick with it.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    If I'm not sure about the CYA level how do I know the proper shock level. Even if I was to wait for a week I'm sure my level and that of the pool store would differ. My tests always show lower than the pool store when it comes to CYA. Which one do I go with and why does there always seem to be a difference? Has anyone else had this problem? Also, if removing water is the only way to lower CYA why does it seem to lower over the winter?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    because it's in there and you know how much you added. 5lbs in 21K gallons is roughly 30ppm cya. so you shock for a cya level of 30.
    don't trust the pool store. on the other hand, some people have trouble with the cya test. here are some pictures to help.
    http://www.taylortechnologies.com/Chemi ... ntentID=36
    There are some kinds of bacteria that can break down CYA. They will only grow when the FC level is zero, and even then they are unpredictable. Since a pool should never have an FC level of zero, the bacteria should never get a chance to grow during the pool season. But they do have an opportunity when the pool is closed for the winter.
    It would be cool if someone figured out a way to use these bacteria to break down CYA on command, but that hasn't happened yet.
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Day 4 (7/8/09)
    4:30 pm - Had water test at Leslie's
    Chlorine - 0
    PH - 7.6
    TA - 100
    Calcium - 325
    CYA - 30
    5:00 pm - Added 8 oz. of acid to lower PH to 7.5
    Added 3 184oz jugs of bleach
    Switched to high speed on pump, Filter still in recirculate mode.
    Noticed another leak at a glued connection this time (My frustration grows). I'm sure I glued everything properly, but felt the glue may not be right. It was a fresh can of Medium PVC cement (blue). It seemed darker than what the pool guy used last year and seemed a bit thicker than the clear PVC cement I've used for my irrigation system. I used primer and followed the directions but still had a bad filling. Another can I bought looked the same, but it was from the same batch. Could the glue be bad?
    5:45 pm - Tested Chlorine which is now a whopping 1. Added 3 more 184oz jugs of bleach. Heading to Costco for more bleach.
    6:00 pm - Added another 12 oz of acid after reading Turning you swamp into an oasis and realizing that my PH should be on the low side.
    6:15 pm - Tested Chlorine which has climbed to almost 2. Added 3 more 184oz jugs of bleach.
    6:45 pm - Tested Chlorine which is about 2.5. Added 2.5 more 184oz jugs of bleach.
    7:15 pm - Noticed a considerable difference in color of water, much lighter green. Water is above 5 so I will test with TF100 kit. I know it isn't up to shock level so I added 1/2 of remaining 184 oz jug. Waiting for wife to come home with more bleach to retest and adjust properly.
    7:45 pm - Tested Chlorine which is about 5.5. Added 1.5 more 184oz jugs of bleach.
    8:15 pm - Level=8.5, Added 1 jug.
    8:45 pm - Level=11, Added 1/2 jug.
    9:30 pm - Level=10.5, This is my last test for the night so I added 1 jug and switched pump to low speed.
    Here are pics as requested.
    That sounds like the correct glue. When making a PVC connection you want make sure there is first primer, and then glue, all the way around both pieces, and then twist the joint as it comes together to be totally sure the glue spreads uniformly all around.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Thanks Jason. I did apply primer on both pieces as well as glue with a quarter turn when possible and I held it in place for about 15-30 sec. It's possible I didn't quite get that piece in place all the way or I stressed it putting another piece in. At least the glue situation is reassuring.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Note: I'm editting a post to reflect things I've done during that day, so for those interested you may want to review the current days post.
    Question: The Turning your swamp into a sparkling oasis it says to test the chlorine level after a shock 30 minutes later. Is that sufficient time to properly distribute and is the test really valid at that point?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes. You can test 30 minutes after and still get an accurate reading.
  20. Back To Top    #20
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Here is what I know from my short time on this forum & clearing my own swamp in May
    You need a LOT more bleach than 3 jugs at a time
    You need to get your pool to shock level, which is FC12 if your CYA level is 30 according to the CYA/chlorine chart & you need to keep it at shock level until your FC level holds over night & you have CC level of .5 or less
    pool-school/chlorine_cya_chart_shock
    This can take 3 days & a bunch of bleach or much longer & a ton of bleach, it all depends how well you do at keeping your pool at shock level and/or how often you let the chlorine level drop to low levels
    Letting your chlorine drop to 0 even for a short time can wipe out all of your efforts
    Good luck, you can do it, I did & I have never owned a pool before this year
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
