Thread: Pentair Great White gets stuck on main drain
    Jax, FL
    21
    Does anyone have any experience with this pool cleaner? Our pool was completed last month and the cleaner worked great in the beginning. Recently the darn thing keeps getting stuck on one of the main drains and doesn't move. I've got to manually push it away from this one drain but eventually it will get back down in the same area and get stuck again. Can someone give me some advice on how to fix this problem?
    23K gal IG pool, Crystal Stone finish, 2.0HP Pentair Whisperflow pump, 200 sq. ft cartridge filter, Intellichlor SWG, Ultra Pure Ozinator, AquaCal H120 heat pump, Pentair Great White cleaner
    Aug 2007
    near the swamp
    804
    Re: Pentair Great White gets stuck on main drain
    Have you tried turning the drain off via valve near the ground by the pump?
    May 2014
    Tampa
    50
    I am having the same issue recently. It never did it before.
    I have tried completely turning off the main drain but it does not help.
    Also verified the brush is actuating every minute or so.
    I watch it move slightly but just won't break away from drain.
    What could have changed to cause this? Surely my brush height couldn't have been reduced over a single season.
    22,000 rectangular plaster. Hayward everything on a C1750 cartridge filter and a Liquidator.
    May 2014
    Tampa
    50
    The idler gears and cam gear were worn causing the cam to not fully rotate.
