Results 1 to 9 of 9
Thread: Using PVC from Filter / Pump (AGP). Silly Question
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    124
    Hey everyone,
    Instead of using the soft hoses, I (like several others have done) will be using PVC for my pump / filter lines for my Above Ground Pool.
    I had a question in regards to the skimmer. The fitting for the bottom of the skimmer "narrows" down from the threaded portion to a smaller barbed type fitting to install the soft hose.
    I did manage to find the correct thread to screw into the skimmer which has a slip fit opposite end where I can glue and slip in a piece of 1.5" sched 40 PVC.
    Does this plastic fitting (original to the skimmer) narrow down for a reason or is it just to connect the hose to it???
    I just want to make sure before I fabricate everything up. I wasn't sure if it possibly gets narrow to reduce flow / help with suction when using the vacuum etc..
    I'm guessing it's just designed that way so it can attach to a flexible hose with a rubber adapter right? Without it, my setup would come right out of the skimmer with a 1.5" PVC hard line and then down to the pump.
    Any problem with this??
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Using PVC from Filter / Pump (AGP). Silly Question
    I'm pretty sure it narrows down to the barbed fitting so the hose will fit over it. You should be good to go with the 1.5" sch 40.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    124
    Thanks Mike,
    I figured that would be the case, (but knowing my luck I'd find out later that the "reduction" was for some sort of reason etc).
    I know others have done sched 40 and I'm guessing they did the same thing I'm planning to do..
    Intex S.W.G.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    in my case...the narrowed barbed piece could just be unscrewed and substituted it with a 1.5" male threaded/slip fittiting...I have a mix of flexible PVC and PVC...it looks messy now (i have some old pics in there too) with the SWG and solar panel, but you can get an idea of the diff fittings needs. I can also advise you to use unions and two shoutoff valves, which makes servicing a snap.
    here is a link to some of my pics where you can see what I'm talking about
    http://s702.photobucket.com/albums/ww30/dmanb2b/
    Apr 2009
    Raleigh, NC
    55
    Here's some inspiration...
    l-cheapo-hose-problems-solved-t14859.html
    93mastercraft - Aqua Leader Reflexion 21' round 54" high above ground pool. This is not a $399.00 Pool! Wedding cake steps, Haywood 1.5 pump/sand filter. If I'd thought taking care of a pool was this easy, I'd owned one a long time ago!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup..I love masters clean lines...the only thing missing is unions...otherwise perfect
    Apr 2009
    Raleigh, NC
    55
    Quote Originally Posted by dmanb2b
    Yep, that's coming later. What you see now was an emergency fix...
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    124
    dmanb2b,
    That's exactly what I'm doing. My skimmer "coupling" also un-screws. I've picked up 1.5" threaded to 1.5" slip fit. Should work well. I'm looknig at your links now.
    Intex S.W.G.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    forgot to mention I used another 1.5" threaded to 1.5" slip fit on my return as well...same concept. Good luck with the conversion
