Thread: Clorine level too high
    Had my water tested and was told that my clorine levels were too high and that I should purchase some expensive instant conditioner. Since I did not like the sales person, I did not buy it.
    Any recommendations on how to adjust (lower) the clorine level?
    Vaughan Williams
    Octopus Pools
    Kyrenia
    Northern Cyprus
    Pool construction, repairs & maintenance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Clorine level too high
    Time and sunlight. What is the chlorine level and what is the CYA level?
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by mriche
    How high was it. Most pool stores go with the recommendation that 2.5-3.0 FC is normal. However, I let my kids swim when it is 7-8 or sometimes even 8-9 FC. How high did they say it was...because High to the poolstore my be normal to most of us.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Butterfly's Avatar
    South Carolina
    10,045
    Hi mriche,
    Have you read Pool School? Link at top right of each page.
    We can only guess about your pool woes unless we have test results.
    Welcome to the forum
    You're done SLAMing when:
