Results 1 to 10 of 10
Thread: How to clean impeller
    Sep 2007
    Toronto
    106
    I noticed a drop in the pump pressure on my Sta-rite Max-E-Pro 1 hp, the skimmer and pump baskets are both clean. The pump is 1 year old and I 've never taken it apart to clean the impeller. We do get a lot of pine needles in the pool. Has anyone done this and is there anything I should watch out?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Aug 2007
    near the swamp
    806
    Re: How to clean impeller
    Undo the clamp ring, pull apart and set the housing o-ring aside, then unscrew the diffuser, then inspect the impeller. To remove debris from them I like to use pipe clears(bendable wires covered in cotton from a craft store) or a zip-tie because it's flexible.
    Sep 2007
    Toronto
    106
    Do I need to apply teflon gel on the O-ring? The skimmer and pump baskets are not too effective in catching pine needles, because they are so thin, they can go right through, I do get lots of pine needles when I clean my cartridge filter.
    OH TWINS
    Sep 2007
    Toronto
    106
    The instruction manuel for the Star-rite pump isn't too clear, after I pull the pump motor portion away, there is a diffuser plate I need to remove, will I be able to get to the impeller after this? Or must I remove the impeller in order to clean it? Also someone mentioned about every time you take the pump apart there is a seal you must replace rather than reuse, which seal is that? I just want to know as much before I actually do it. Thanks.
    OH TWINS
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    When you're through with that project, you might want to give skimmer socks a thought. They have helped me greatly with my millions of pine needles. Last year, I thought I had a clogged impeller, but I found the impeller turned easily manually when I started to investigate. Turns out I had a large clump of pine needles stuck behind my light fixture/return. I was able to break apart the clump and fish them out with a heavy duty plastic wire-tie.
    Good luck!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Quote Originally Posted by Ke
    Yes, you'll find the impeller directly behind the diffuser plate. You won't have to remove the impeller to clean it. The seal that you mention that needs to be replaced every time a motor is replaced is between the impeller and the motor, so you won't need to worry about it.
    Aug 2007
    near the swamp
    806
    Yes, lubricate those o-rings. Replace them if they're not round, or squared.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Ke, I have to do this about every other weekend due to pine needles. I'm amazed that you haven't had to do it in a year! You definetly need to get skimmer socks. I have come to the conclusion that they are critical in my case. They really help with catching the needles. When I open the impeller up, it usually looks likes strings on a vacuum! I just hose it out and dig them out with a screwdriver and hose some more until they're all out. I've become a pro!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Sep 2007
    Toronto
    106
    Yes, I'll give skimmer socks a try, I am worried that it might slow down the flow.
    OH TWINS
    Sep 2007
    Toronto
    106
    With all this information on hand, I took my pump apart today, everything went as planned, removed lots of pine needles from the impeller, the pressure immediately went from 9 to 15 psi, big difference! I also put on a skimmer sock for the first time, so far so good.
    I am so glad I could do this myself, my pool is about 1 year old, so far I have been doing all the up keeping myself, my PB does not do pool maintenance. Here in Toronto, Canada, I guess the economy isn't as bad as it seems, it is very difficult to get tradesman to do small jobs, my friend just bought a house with a swimming pool, when she called a well known pool company they refused to accept new clients.
    Anyway, thanks everyone for the help.
    OH TWINS
