Thread: Goldline Valve Acutator Installation GVA-24
    I am trying to configure the valve and running into a lot of issues.
    Here is what I am trying to do. The majority of the time I want the filter to take in water from the skimmer only. For about an hour a day I want the filter to take water from the skimmer and vacuum at about 50% each.
    I have tried multiple configurations but cannot figure it out.
    Here are my questions:
    Is this possible?
    Over which pipe should I place the valve?
    what position should the small slot be in? 12 o'clock?
    What position should the cams be in?
    Should I be using on 1 or on 2?
    Sometimes the valve spins without stopping and I only want it to turn 90 degrees. Sometimes it turn 270 degrees!
    Please help!
    Duluth, GA
    27,000 gallons
    In Ground Vinyl
    Hayward S-240 Sand Filter
    Hayward Super Pump (C48K2N143B1)
    Apr 2009
    Northern Virgina
    Re: Goldline Valve Acutator Installation GVA-24
    I just got an Aqua Plus system and hooked it up to two valve actuators for my pool/spa. I don't think it's possible to do what you want. I think you need to decide which way you want the valve to operate:
    1. A or B
    2. A or (1/2 A AND 1/2 B)
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Mar 2007
    Coastalish 'down easter'
    Welcome to TFP!!
    Can you give us a pic of your system's valve configuration?
    How the lines come in and the valve is positioned make a difference.
    The toggle switch positions simply set which of the 2 end points are the starting and ending point when it actuates.
    The Goldline models are IMO the easiest to recam 8)
    Best I can say is to recam the unit to be closed on the vac line valve as 'normal' operation and then, have it stop 1/2 way between the two ports the other 2 hours
    Your question is slightly vague and my answer is even more so without the plumbing lay out :P
    Please let us help you by giving us a little more info on the set up
    Luv& Luk
