Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: Question about CYA
    Kentucky
    69
    Question about CYA
    Pool not in yet but I am a little confused about where to purchase CYA.. Can I get this someplace other than my pool store??
    1) 16500 gallons
    2) 150 lb sand filter
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Re: Question about CYA
    CYA is often sold as stabilizer or conditioner and should contain 90+% cyanuric acid.
    It is available in pool stores and in the pool departments of many big box stores (Lowes, Home Depot, WalMart, etc). The big box stores don't always bother to keep it in stock however.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Wal-mart, lowe's home depot usually, csometimes it is called conditioner or stabilizer , I think. Just look at the ingredients for Cyanuric Acid
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Kentucky
    69
    Thank you!!!!!
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Kentucky
    69
    http://www.lowes.com/lowes/lkn?action=p ... lpage=none
    Is this the correct stuff to buy??
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by momof3
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=128371-23132-10089&lpage=none
    No, this is it http://www.lowes.com/lowes/lkn?actio...050&lpage=none
    At most Lowe's stores.
    Kentucky
    69
    OH..
    And this is for the CYA?? Is this the granular kind?
    I am going to need an entire bottle plus another 10 oz. of this stuff.... wow
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Yes, the link JohnT gave is for granular CYA. Lowes also caries two other brands of the same stuff.
    Kentucky
    69
    Can the kids swim while the cya dissolves??
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I don't see why not. If you're dissolving it in a sock in front of a return, I'd probably tell them to leave the sock alone, but other than that, go for it.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Kentucky
    69
    How do I tie the sock onto the return? Is the return the same thing as the skimmer?
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Tie a string or small rope around the sock,(tie up end of sock too).
    Find something outside the pool to tie off to(chair,tree) and toss the sock over in front of the return.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    It is much simpler to put the sock in the skimmer, it works just as well there.
    Kentucky
    69
    I put the granular CYA in panty hose but it was wayyyyy to long to fit in the skimmer.. I tied it so it hung in front of the return but only a small part of it is actually near the return.. The panty hose was stretched about 2 or 3 ft long.. Is that right??
    Also, the part that is in front of the return has white stuff blowing out of it.. Is this also right??
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, that's right, and seeing the white bits is normal... If you can make the sock shorter, so that the bulk if it is in front of the water flow. I tied mine to the outside of the return, around the end of the hose fitting where it goes into the pool. That length was perfect for the sock to dangle in the flow.
    Kentucky
    69
    I shortened it a little by tieing a not so it dangled in front of the return but it kept twisting around and around... HOpefully it wont twist so much it comes off..
    So, now that I have added the bleach and the CYA what's next? When should I test again? In the morning or evening? Should I test for everything or just the bleach??
    Thanks
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    When have you been adding your chlorine? In the evening? Have you already tested the pH, TA, and CH?
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Kentucky
    69
    The pool was just installed on Tuesday so Wednesday evening was the first time I added any chemicals to it. I tested the water out of the faucet and that was how I got my readings..
    I will test the water this morning and post it to see if I need anything right now..
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
    Kentucky
    69
    Here are my numbers for Friday Morning 6:30 am
    FC= 3
    CC= .5
    TA= 70
    I just added CYA for the first time last night so I didnt test for that.. Should I add more bleach this morning or wait for tonight??
    I also didnt test for PH because nothing was added to change it. Should I test for that anyway??
    1) 16500 gallons
    3) 28' AG DoughBoy
    4) Vinyl
    5) 1.5 hp
    6) TF-100
  20. Back To Top    #20
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    did you shoot for 30ppm cya or what? you could stand to add a little more bleach as your cya starts to work. you don't want to go below minimum which is 2ppm.
    ph is part of the daily testing routine. pool-school/basic_pool_care_schedule
