Results 1 to 10 of 10
Thread: Possible filtration/pump issue with clearning deep end
    Jun 2008
    Vienna, VA
    15
    In my vinyl lined, sand filter pool (35'long x 17'wide, oval) I have one return. I am relatively new to TFP, but have gotten rid of a really bad green algae problem. I have one issue left - the deep end never clears up. My deep end is 8' 6" and the shallow end is 3'. The return is at the deep end. I have it pointing horizontal to promote circulation, but I am not sure if the water down low is getting a good stirring. Oh and another note, I do NOT have a floor drain. I have been doing an experiment where I sink my vacuum hose (I have a pool vacuum port on the side of my pool, separate from the skimmer) into the deep end to promote water circulation down low.
    Any suggestions, ideas? Should I point my water return down low? Is the cloudy water deep just something I have to deal with?
    In-ground, vinyl pool, full sun - 23K gallon, Leslies (Hayward) pump, Hayward 60 sq ft (300 lb) sand filter
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Re: Possible filtration/pump issue with clearning deep end
    Do you have a drain on the bottom of your deep end?
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Jun 2008
    Vienna, VA
    15
    Nope. No floor drain
    30,432
    JT,
    Point the return down. That should help.
    What do you mean, "never clears up"? Algae? Cloudy?
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    You can connect your vacuum and leave it in the deep end for a while, and it will pull water from the deep end.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    Jun 2008
    Vienna, VA
    15
    cloudy - milky blue.
    I had algae, but I think I am getting that under control
    22,553
    I think your approach of sinking the vacuum is a good idea also. I'd also point the return down.
    Where is your skimmer located in relation to the deep end?
    Jun 2008
    Vienna, VA
    15
    Skimmer is closer to the shallow end, on the beginning of the slope from shallow to deep. Probably about 8' away
    Jun 2008
    Vienna, VA
    15
    When you say to point the return down, so I forgo the circulation?
    22,553
    I would point the eyeball down as far as I could and slightly away from the skimmer. In all honesty you will probably have to play with the aim until you get it the best it can be.
