Thread: First problem
    First problem
    Split from first-problem-checking-in-t14667-20.html Butterfly
    My pool looks just like this have you found away to get rid of it?
    17x34 21000 gal IG. Hayward super pump/sand filter. BBB convert!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: First problem
    Hi cindylouwhoo23,
    Please start a new thread to post your questions (rather than tag onto another member's thread )
    Could you describe how your pool looks or post a pic?
    Do you have a set of test numbers?
    If you go to Pool School, link at top right of each page, it will give you the info to get started.
    Welcome to the forum
    You're done SLAMing when:
