Results 1 to 9 of 9
Thread: What is SWG?
    What is SWG?
    What is SWG?
    Peter T
    17500 IG gunite saltwater with 2 Jandy (1.5 and 2) with cartridge filter 150 gpm flow rate and Solar heat. Aquacell NACL converter. Chlorine FAS-DPD Service Test Kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: What is SWG?
    Quote Originally Posted by peternmdds
    What is SWG?
    Saltwater Generator
    a/k/a Saltwater Chlorine Generator
    You're done SLAMing when:
    Re: What is SWG?
    So is this the Aquacell? The unit that converts the salt to Chlorine, this is a SWG?
    Peter T
    Aquacell = SWG????
    Is an Aquapure Aquacell an SWG.
    Peter T
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Aquacell = SWG????
    Are you talking about this? Yes, it is a saltwater chlorine generator (SWG). I can't find any brand called Aquapure that makes Aquacell. Aquapure makes water filters. Do you have a link to exactly what you are talking about?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: What is SWG?
    yes.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    please stay with one thread.
    Topics merged. JasonLion
    Re: What is SWG?
    great...thank you.
    Peter T
    Yes...that is exactly it. I have found out it IS an SWG. Thank you for the reply.
    Peter T
