Thread: Tri Sensor Cable
    Tri Sensor Cable
    My dog had chewed completely through the tri sensor cable on my soft touch unit, I bought a new one and am still receiving 4 flashing lights on the panel under service. The unit wasn't producing clorine at all, that's when I discovered the cable, I also put in 2 bags of salt but the low salt light is also still flashing. Any suggestions would be greatly appreciated.
    Thanks and Happy 4th, Janet
    [center:tq5nl1sl]Debbie Kemp...Pool Owner in Ohio ;)[/center:tq5nl1sl]
    Re: Tri Sensor Cable
    Welcome to TFP!
    The first thing to check is that both ends are securely connected. It might also help to cycle power on the SoftTouch.
    I checked the connections and they seem to be correct, I turned the whole system off and back on a few times, when you say cycle power on the soft touch - I'm not sure I understand what you mean I should do. Thanks
