Thread: Question about booster pump.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    This might be a silly guestion but. Should I close the valve to my booster pump when I'm not running it? By leaving it open, I get water out the return it's hooked to,(presure cleaner not hooked up) so it's kinda like another return. Just didn't want to do any damage to the booster pump by doing this.
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Question about booster pump.
    I'd say leave it open, the extra water flow to the pool isn't hurting anything and regardless the less often you touch a valve the less often it will need to be replaced
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
