Results 1 to 7 of 7
Thread: Bleach on hand
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Bleach on hand
    Just curious as to how much bleach you store on hand? Here in Texas we do not have the abundance of deals on anything over the standard 6% variety. I have been using Sams club Clorax as it is convenient and an okay price. I buy three cases at a time and store it in the laundry room (air conditioned) to keep it away from the high heat that we are going through right now.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Bleach on hand
    I buy a case of 12.5% and it lasts about a month, give or take.
    Re: Bleach on hand
    I buy 10 gallons of 12.5% from the pool store maybe every 2-4 weeks depending on the heat. Here we get the 5 gallon jugs of 12.5% for $12. Very reasonable if you ask me. I keep it outside but in a shady area in the back of the yard. So it sees the heat but not the direct sunlight.
    I do use bleach from the grocery too for the times I travel. My wife can put in (1) 128oz bottle every-other-night and it works fine until I get home to readjust. In that I case I normally keep 3-5 128oz jugs in the garage until gone. It could be a month before it's all used if I don't travel much.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Bleach on hand
    We normally keep a weeks worth of Wal Mart brand bleach on hand, 96 oz size and we use 1 jug ($1.58) a night. Pretty cheap maintenance if you as me !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Re: Bleach on hand
    I buy a dozen every 10 days or so
    2003 Marquis Euphoria - 400gal
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Bleach on hand
    4 gallons of 12.5% chlorinating liquid every month.
    Arizona
    924
    Re: Bleach on hand
    Quote Originally Posted by chem geek
    Same here.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
