Thread: Bleach
    May 2009
    Florida
    45
    Bleach
    Is it safe to use bleach when shocking a pool with a pebbletec surface?
    14,275 gallon inground ~ Pentair Cartridge cc200 ~ Pebbletec Tahoe Blue ~ SWG Intellichlor IC40 ~ Pentair Whisper 2hp ~ Taylor FAS-DPD Test Kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Bleach
    Yes, how new is the surface?
    Guest
    Re: Bleach
    chlorine is chlorine! Bleach and liquid chlorine or shock are one and the same thing in different bottles (and sometimes, but not always, at different strengths). All forms of chlorine form hypochlorous acid and hypochlorite ions once in the water. Doesn't matter if it came from bleach, trichlor tabs, or chlorine gas injection (or any other form of chlorine available).
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Bleach
    kenny, chances are you can get liquid chlorine at the pool store for a lot cheaper than bleach, especially considering the strength differences.
    Re: Bleach
    Bleach should be added by pouring slowly in front of a return jet (with the pump running). Always add chemicals with the pump running.
    May 2009
    Florida
    45
    Re: Bleach
    Thanks for the responses. The surface is 2 months old.
