Thread: How often can I test and add chems
    How often can I test the water after adding chems?
    How often can I add Chlorine and/or acid to get the to appropriate levels?
    Mike Marchi
    Southern California
    14000 Gal IG Pool, Dark Grey Plaster, Purex 4000 DE Filter (54Cubic Ft), WisperFlo 2HP pump
    Purex 400000 BTU Heater, Navigator Pool Cleaner, Granite waterfall with 2HP pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: How often can I test and add chems
    1. as much as you want. I would wait at least a half hour after an addition to start though.
    2. wait a half hour, measure, add more if necessary.
    make sure your pump is running.
