Thread: Now I have a ring around my pool
    May 2009
    Ontario, Canada
    84
    As I vacuumed this morning I noticed a ring around my pool at the water level. It is greenish brownish...Stain. It is not slimy or scummy....just a stain. It's not coming off at all.
    I have been doing the MA all week. IL or so in the morning and have my return pointing up and the pump at high speed to aerate. The stain ring is much more pronounced at the end the water is jetting to.
    Is this as a result of the 5L of MA I've put in so far?
    Last nights numbers:
    FC 3 (which I then shocked to 5)
    CC less than .5
    TA about 175
    PH 7.5
    CYA is about 30 from what I can see but a full week has not gone by yet.
    21' 54" Round AG, 10K gallons,1HP 2 speed pump, Sand filter 200lb
    Have had a sparkling BBB pool all summer....
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Now I have a ring around my pool
    I haven't read thru all your posts but have you ever used any copper-based algaecides or products with copper?
    Try a Mr. Clean Magic Eraser. If it will work, you won't have to scrub hard at all. If you have to scrub hard don't use it.
    Report back if it doesn't work.
    May 2009
    Ontario, Canada
    84
    hi frustrated pool mom...no i haven't added anything but bleach and MA. i did buy and will try the magic eraser.....although the erasers are full of italian lemon soda now...(see my last post regarding vacuum problems and tripping with my grocery bags .....)
