Results 1 to 7 of 7
Thread: Water Evaporation or Pool Leak
    Kentucky
    2
    1st I have to say I love this site!!! for the last 2 weeks I have found some great advice.
    My husband and I are at a stale mate. Our pool has been filled and in operation for exactly two weeks. When we filled it up we made sure that the water was in the middle of the suggested two lines on the skimmer. Today I went out to check the chemicals and noticed that the pump was acting funny. After investigating I noticed that the water level had dropped below the suggested line. It was about a 2.5 inches of loss water. There are no wet spots around the pool. For the last 3 days, the weather has been mild to cold with no rain. We have not been in the pool in two days because of the weather being so cold. We also run the pump 24hrs. Until today our chemicals have always been great.
    Can you pool lose that much water of 2 weeks. Do you periodically have to put more water into your pool? and do you need to run the pump for 24hrs or can you just run it for 8 or 12 hrs
    Any guidance is appreciated
    Above Ground Doughboy Dessert Springs
    Oval 16x28 Pool; 10500 Gallons
    Hayward Sand 2hp pump; Frog Mineral System
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Water Evaporation or Pool Leak
    pool school has some good information on both of those issues. the link is in the top right of every page.
    pool-school/
    pool-school/leak_detection
    pool-school/pump_run_time
    Kentucky
    2
    Thanks for the info
    My DH and I went back out and looked all around he pool and under the deck. I am 98% sure we don't have a leak.
    Is it common for you to have to add more water to the pool after 2 weeks?
    Mar 2009
    Glendora, California
    169
    2 weeks doesn't sound like a problem to me. Here in So Cal I'm adding water at least once a week! I think that's just evaporation, but you can do a bucket test to know without a doubt.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Arizona
    924
    Don't know where you are but here in Phoenix, we can lose 1 to 3 inches in one day from evaporation in the summer. In the winter I lose maybe an inch every week or 2.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    22,553
    It's not unusual to loose that much water due to evaporation.
    The bucket test is the best way to tell that it's evaporation.
    Take a bucket and fill it about 2/3ds full of water. Sit it on the top step and either mark the water level or measure it precisely. Then mark or measure the water level in the pool. The next day measure how much the level in the bucket and the pool has dropped. Compare the two and they should have the same amount of drop. Don't run fountains or such during this time.
    I did ours for two days. The funny thing is that the bucket lost 1/16" more water than the pool did.
    I am in MN.. very humid.. I lose 2-4 inches a week.
    2003 Marquis Euphoria - 400gal
