Thread: New Pool - first steps?
    I have a 18x4 pool how much bleach should i put in it.
    ~15000 gallon inground, plaster pool
    Jandy CL460 Cartridge Filter Tank, Jandy Stealth SHPF 1.5hp pump, Pentair Legend II cleaner
    Leslie's DPD Complete Test Kit, TF Tests FAS-DPD Chlorine Test Kit
    Heliocol solar pool heating (HC-40 x6)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New Pool - first steps?
    Welcome to TFP.
    We need more information to advise you better.
    Type of pool, how many gallons, type of filter, type of pump...
    You can put these things in your signature. Go to User Control Panel, then Profile, then Edit Signature.
    Is this a new pool? Just filled from a hose? Is it an Intex-type easy set pool?
    How does your water look?
    Do you have a way to test the water?
