Thread: Plumbing Returns Opinions Requested
    May 2009
    Enterprise, AL
    The PB says he normally plumbs the two returns (plus an eyeball on the steps) together, one return on opposite corners of the ends. I think I would rather have individual lines for each return with ball valves for each. I also want them to add a third return low on the sidewall to aim down into the 8' hopper. They also normally run 1.5 inch lines and I'm having them use 2" instead.
    What do you think is the best option?
    20K gal IG vinyl 18'x36' rectangle, 2' radius corners
    Hayward Goldline Aqua Rite 40K SWG, Pentair Intelliflow VS 3050,
    Sta-Rite Cristal-Flo 24" Sand filter, Model T-240BP-1, Polaris 280 Auto Cleaner
    Sunstar solar panels (438 sq ft ), Pentair Sun Touch Controller automating solar panels, SWG, and Polaris
    TF-100 test kit
    Re: Plumbing Returns Opinions Requested
    There are many different ways of plumbing things, and for the most part all of them work. Two returns sharing a 2" pipe would be fine. Running a 1.5" line for each return is also fine. Running a 2" line for each return won't hurt but is probably more than you really need.
