Thread: bleach instead of tablets
    Can anyone please tell me how much bleach to use in the place of the tablets? I have an above intex pool 16 x 3.5 and am planning to use bleach.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: bleach instead of tablets
    Welcome to TFP!!
    If 3.5 is the water depth (not the wall height) your pool holds ~ 5300 gallons - if the wall height is 3.5, you have ~ 4500 gallons
    To figure out chemical additions, all you need do is click on the "Jason's calculator'' link in my sig and put in your numbers 8)
    It'd be nice to have all your pool chemical numbers but, if all you are worried about is the bleach - that's fine, just be sure you know the % of the bleach you will be using when you go to the calculator.
    If you haven't already done so, PLEASE read Pool School (also linked in my sig) a couple of times so that you understand ~ what we recommend and WHY we recommend what we do
    Have a great summer with the pool (Mark is lucky to have you as his pool girl! you knew enough to come here to do the job right )
    Luv& Luk
    -Ted
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Ted gave you great advice.
    Is this a newly-filled pool with fresh water? Have you added anything to the water yet?
    Do you have a way to test the water?
