Thread: am i using to much reagent for test
    hawkeye's Avatar
    davenport,iowa
    118
    im almost done with conversion i am trying to do overnighttest and im using like 75 drops to test this water to 15ppm? is this right on solution usage?
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: am i using to much reagent for test
    probably not if you are using a 25ml sample...you can cut down on that by more than half if you use one scoop of DPD powder and a 10ml water samle...then each drop will count as .5ppm instead of .2ppm...your way is more precise, but not really necessary.
