Thread: Looking for a SWG
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    Looking for a SWG
    HIGH! Yes, I am high on bleach right now as I am converting from the baquacrap to BBB! But we want to use a saltwater gen since we had one before...when we were chlorine users with an Intex pool...but am seeing that maybe we won't be able to do it because of the sand filter. Any recommendations on a SWG good for sand filters that won't eat up my water since our water prices just went UP UP UP here in Southern Virginia? I read that maybe just adding the blue bagged water softener salt to the water would give me kinda the same effect?? It's been a while since we've used a SWG so I am out of the "loop".
    15' RND 48" AGP 5,300 GAL
    16" Sparco Sand filter,I got a new pump in 2010, but not sure what it is
    Successful Convert to BBB and lovin it!
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    Re: Looking for a SWG
    Guess I should add that we have a 15' round 48" deep pool with a 16" sand filter.
    kernelpanic's Avatar
    Fort Worth Area, Texas
    10
    I've read several posts here where people have successfully done a swg with a sand filter - I hope that having a sand filter won't be an issue since I just bought the Intex swg for our pool. Wallyworld has them on their website for 159.99 - our local store had them in stock (despite the website saying it was available "online only") - price in store was 199.99.
    AG 24' round
    pentair sand filter SD-60
    Hayward SP15922S - 2 speed
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    not a problem at all...I run mine on a sand filter with now issues....the reason they say that with the intex is that sand filters have the backwash option and can fluctuate your salt levels...I don;t plan on backwashing more than twice this season...so as long as you keep an eye on your salt level and maintain the recommended water balance for SWG's...your all set
    Also...using the blue bagged water softner salt is what we prefer to use it is cheaper than pool store salt, it's just a little courser, but not worth the added expense...99.6% or better pure solar salt is what your looking for...not the softner salt bags with additive such as to combat iron
    poolmomma's Avatar
    Jul 2009
    Southern Virginia
    78
    Thanks dman! I knew about which salt to use because of prior usage, but using it with sand and backwashing...which I will be doing a ton of here over the convert process...sounds FANTABULOUS!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Your welcome...yeah...sorry didn;t realize you were in the conversion process, but that should be an issue as you won;t be running the swg during the conversion, but rather after and your backwash frequency will go down as well once your water is all sparkly ...good luck
