Results 1 to 9 of 9
Thread: First Test - Newbie
    First Test - Newbie
    Hi Everybody -
    I just got my test kit in and here are the results of my first test:
    FC - 3.5
    CC - .5
    TC - 4
    PH - 7.2
    T/A - 600
    CH - 460
    CYA - 50
    On my salt level test the top band turned dark but their is barley any white on the bottom maybe three lines up (not to the one mark)
    Thanks for your help
    Tammy Sue in Texas
    Thanks Tammy Sue in Texas
    in ground pool
    20,000 gallons
    pool surface: plaster - diamond brite
    Filter - Pentair clean and clear 200 cartridge
    SWG - Pentair Intellichlor
    30,421
    Re: First Test - Newbie
    Hey, TS,
    Welcome to the forum!
    1. I can't remember....tell us how your water looks.
    2. Your numbers are all pretty good with two exceptions that will require some attention.
    The first one is your TA of 600. That's very high and there are two possibilities.....testing error or it really is that high. I suspect testing error. During the TA test the R-0009 (that's the one you count) can develop static electricity and cause the drops to come out of the bottle very small (they almost shoot off the end rather than fall). If that's your case, redo the test and wipe the dropper tip every few drops with a damp cloth or paper towel. That should get you a much lower result. The other possibility is a mixup in the procedure on the test. reread the instructions and make sure you have added all the right "stuff" in the right amount. Post back your findings.
    The other issue is your CH but that's a long term thing that can be manged pretty easily. Let's discuss that after we resolve the TA question.
    Sorry for the bad info:
    It is an inground pool
    Pool water is clear
    TA - 170
    Also white calcuim flakes have been comming from the jets in the pool and hot tub. I have acid washed the SWG and the filter.
    We have been brushing the pool sides but not every day.
    We have some green algea on the rocks, grout and a little on the tile.
    We have black spots of algea in the bottom of the pool.
    Thanks for answering so fast!
    in ground pool
    20,000 gallons
    30,421
    1. The TA of 170 is a tad high but manageable for now. I would suggest dealing with it later.
    2. The presence of visible algae certainly indicates the need to shcok your pool. Using Clorox, (not the SWG) bring your FC up to 20ppm and hold it up there by constantly testing and readding clorox until the algae is gone and your pool is crystal clear. You may have to add Clorox 2-3 times daily to keep it at 20 but the idea is to hold that very high FC level and you will eliminate the algae. Read "How to shock your Pool" in Pool School for more details.
    3. Once you complete the shock process....and it is a process not a one time dosage.....I think you will be able to turn down the % on your SWG significantly.....that's a good thing.
    4. You CH is a little to high and is likely contrubuting to the white flakes you see. Perform a CH test on the fill water that you use to refill the pool and post that result. I think I would suggest a partial drain to get your CH down below 400 but let's see how high in CH your fill water is first.
    5. Almost forgot. I do not have a salt pool. Others will advise on that soon.
    Your FC is too low, which has caused your algae bloom. I suggest shocking your pool according to this chart
    ETA: Dave beat me to it!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    OK - The CH on our water that we fill the pool is 350.
    Also the intellichlor says that our salt level is good, but I am not sure how to read the test strip? I am not sure is we need more salt or are we ok. The test strip made it to the third line from the bottom.
    I think we need to do the shock, then retest and see what we need to do then? Let me know if I am on the right track, please. When your doing the shock process should we stay out of it?
    To bad I did not find ya'll a few months back. Thanks for all the help.
    in ground pool
    20,000 gallons
    30,421
    That is absolutely the right track.
    I will swim in much highler levels of FC (the FC in the machine when you wash clothes is 250ppm+) than shock but others here on the forum will not. The potential for a faded swimsuit I suppose exists but we have yet to have one reported here on the forum.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Tammy Sue,
    Here are detailed instructons on How to Shock Your Pool
    Great information in Pool School!
    Would you describe the black spots on the pool floor?
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, if that is in fact Black Algae, it's important to brush frequently, at least twice a day while the pool is at shock level. BA is very resistant to chlorine. It has a tough outer shell that protects the inside, you have to brush to break thru the top layer - or 'heads' - to allow the chlorine to destroy the underlayer.
