Results 1 to 9 of 9
Thread: Should I buy more BioGuard Smart Sticks?
    Ok.. this is my second year on BBB.. well sort of.
    I am also using BioGuard SmartSticks (a 30lb pail was given to me as a gift when we moved into our home). I am now out of the SmartSticks. I always kept two in each skimmers to get my CYA up. Well, it hasn't really worked because my CYA is only about 10-20 (liner was replaced last year).
    So, my options are:
    #1 Get another bucket of SmartSticks and continue what I am doing
    #2 Save some money and go with sticks from Doheny's
    #3 Only use Clorox and buy some CYA and introduce via the sock method
    I am guessing most of you will recommend #3?
    My only concern is I can't always check the FC everyday. Using the SmartSticks buys me some time.
    Latest numbers:
    FC: 2.5
    CC: 0
    TC: 2.5
    pH: 7.4
    TA: 120
    CYA: 10
    Thoughts?
    2003 Marquis Euphoria - 400gal
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Should I buy more BioGuard Smart Sticks?
    #3. No question.
    I would say go what works for you. If your CYA was not outrageous after using the sticks, and you were able to keep a safe pool, then I would say keep doing what you are doing.
    However, perhaps if you got your CYA up a tad higher, you would not NEED the back-up of the sticks, and you could dose with bleach instead? Many people test daily but only add bleach every other day...
    Do you know when you will be away? Then you can add a puck in a floater (or the sticks, but they are more $) when you are going to be gone, and remove them and resume daily testing and bleach when you return.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    are these things acidic like trichlor? if so, you don't want them in the skimmer unless you run your pump 24/7.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Smart Sticks are technically supposed to stop dissolving when water isn't moving over them, specifically for use in skimmers, but your best options are still 3 then 2. I can't think of any Bioguard product I would recommend unless your main concern was putting the store owner's kids through a real nice college.
    Ha.. yea the sticks the only dissolve with moving water.
    I think I am going to get my CYA up to 40 and stick with BBB.
    Guest
    Quote Originally Posted by The Mermaid Queen
    Have to agree with this. If trichlor is working and you are not overstabilizing and you pH is stable then go for it. One caution, even though Bioguard says they are safe for skimmer use I would be cautious. Remember, this is the SAME company that says CYA up to 200 ppm is NOT a problem!
    Trichlor is NOT the enemy. Improper use of trichlor is!
    My main concern is your very low CYA levels duing the heat of summer. No matter what the chlorine source you are using the low CYA could lead to problems.
    Thanks. I think if I get my CYA up I will be ok with just BBB!
    You all rock!
    30,403
    Minor Hijack:
    Evan, You are a wealth of information.....I didn't know that. They apparently function that way for JJ (only work when ther's flow) Do you (or anyone else) have a similar experience?
