Results 1 to 20 of 20
Thread: What am I doing wrong?
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Drained and refilled the pool yesterday with water from a fresh water stream.
    Poured a 182oz bleach in last night, tested this morning and numbers are...
    3.5 fc
    0 cc
    7.8 ph
    20 ta
    0 cya (new water)
    water is clear with a green tint, which tells me there is something going on, but the test results say there isn't.
    Am I doing something wrong with the TF100 kit?
    I fill to the 10ml mark add powder, water turns pink drop R871 1 at a time, add 5 drops of R003 and nothing changed.
    help.....
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    Feb 2008
    Denton, TX
    5,061
    Re: What am I doing wrong?
    Doesn't sound like you're doing anything wrong. Let me ask you this, has your FC held overnight? Also, since filling, have you been running your filter? I would keep chlorine in it and not let it drop to zero at any point, start getting some CYA in there, and keep the filter running constantly to see if it clears.
    Keep an eye on your pH as it is at the upper limit. At some point, you are probably going to want to get your TA up as well.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I don't think you are doing anything wrong.
    Hopefully you have some muratic acid on hand, and some baking soda. You need to get your TA up, target 90 and then wait a few hours and recheck the PH, and if it's up, lower it down to 7.6.
    As for the chlorine, it will be gone by the end of the day without CYA, so hopefully you are getting that in there? Keep adding chlorine to keep it up throughout the day, and make sure it's holding overnight. If it's not holding overnight you will have to raise it to shock level, perhaps once if the water is clear.
    30,431
    MF,
    The test results will not confirm the presence of algae.
    While your results look good, remember you loaded the pool from a stream which already had tons or organics (algae) in it.
    You need to get CYA in the pool to protect the chlorine and LOTS of chlorine in the pool to kill the algae.
    259
    Pump has been running, chlorine dropped by 2ppm over night.
    My concern is before I drained the water was green & cloudy to the point of not seeing the bottom.
    My test results were about the same, showing no CC with the filter running for 3 weeks and couldn't see any change in clarity.
    Thought maybe I was missing something in the testing.
    Confer E9120 Steps
    11,969
    If you lost 2ppm you need to shock. Get some bleach and CYA in there pronto!
    259
    MF,
    Hmmmmmm.... I assumed the test would show CC confirming a problem...my bad.
    CYA is already in a sock in my skimmer basket dissolving as we speak.
    Confer E9120 Steps
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I agree with FPM...af few years ago we had water delivered to fill our pool...turns out the trucking co never told us it was pond water...as soon as we added shock it greened up. Raise your water to shock level and hold it there until you lose 1ppm of FC or less overnight...good luck
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    I also thought that 0 CC meant that there was no problem? Am I wrong??
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    30,431
    Yeah, that's a little confusing. An unhealthy pool may or may not have CC's. A healthy pool will have virtually none.
    So, the presence of CC's (1.0 or greater) is a problem that needs attention. However, the absence of CC's doesn't mean you are out of the woods.
    259
    Another reason to never assume....
    Confer E9120 Steps
    259
    I NEED MORE POP!!!!!!!!!!!!!!!!!
    Slowly getting there.
    This evenings numbers as of 8:30
    FC 11.5
    CC 0.0
    PH 6.8
    TA 40
    CYA 40
    Still have a green tint but it is getting lighter.
    The sock I was using to dissolve the CYA in seems to want to play catcher, so I have left it (an old hunting sock) in my skimmer basket as a "skimmer Sock"
    Added a Gallon of bleach to get to the now known 16ppm shock level and added a box of Borax to lift the PH.
    I'll work on the TA when the water clears and we have some spill out and/or evaporation.
    Confer E9120 Steps
    11,969
    You may want to work on the TA sooner, perhaps tomorrow - if you get a chance before festivities....add some Baking Soda to raise it to 70. When TA is that low you can have dramatic fluctuation in PH.
    259
    No festivities tomorrow, I'd be surprised if it even has a human sniff at it.
    Other than the challenge of having the clearest water around....... I don't use the pool and the wife floats on top a couple of times a season. Not real sure why we have the thing.
    Confer E9120 Steps
    11,969
    That pretty much sums it up. I have the sparklyiest water in town and I float at will.
    259
    Ok FC dropped 1ppm overnight from 16 to 15.
    took it back up to 16 and will hold it there until it doesn't drop but water is starting to sparkle.
    I will be getting in this evening to vacuum real good and to mix it up a bit.
    latest #'s from this morning were
    FC 15
    CC 0.0
    PH 7.8
    TA 70
    CYA 40
    Just took it back up to shock level a few minutes ago, hopefully it will hold overnight and I can start letting it drop to normal levels.
    Still need more pop though.
    Confer E9120 Steps
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    you are done shocking when you lose 1ppm or less overnight and cc's are .5 or less.
    pool-school/shocking_your_pool
    259
    Bumped it back up 1 more time this morning, but water is sparkling now so I will let it drop to normal level and continue maintaining it with my 2 liter bottle a day bleach habit.
    Confer E9120 Steps
    30,431
    Okay, MF, very nice work.
    Now you and my neighbor, Ivyleaguer, can get back focused on Hockey.
    I almost forgot either of you had pools!
  20. Back To Top    #20
    259
    Hockey???
    Oooooh right .... that game on ice..... I understand a team close to me won the grand prize... or something like that.. 8)
    Confer E9120 Steps
