Thread: Cloudy Pool Plese Help!!
    Jul 2009
    Adrain, MI
    3
    Two weeks ago I opened our pool. Didn't look to bad. Topped of the water and started pump & filter 22inch meteor sand filter 1.5 hp Pentair Pump
    I could see the bottom before I started sweeping and I didn't get half done before pool clouded over and i haven't seen the bottom since. Have tried a clarfier twice doesn't seem to help. My test results from the pool place are FC-3.8 TC-3.8 TA-74 PH-7.1 CA-257 CYA-9
    Have been trying to raise stabilazer for over a week can't seem to get past 9.
    Pool is 24 ft round 52in walls approx 14500 gal water
    any ideas will be greatly appreciated thank you
    24' round AG pool 52" high Pentair 1.5 Dynamo Pump 22" Meteor High Rate sand Filter
    SE Michigan
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Cloudy Pool Plese Help!!
    Welcome to TFP!
    How did you add the CYA?
    Can you put your info/equipment in your signature? Go to User Control Panel (top left), then Profile, then Edit Signature.
    Jul 2009
    Adrain, MI
    3
    Thank You for the help
    the cya is of the pool store test. the last 5 days I've put in 6lbs of stabilizer and the most it moved according to their test was 6/19 cya-8 6/22 cya-6 6/24 cya-6 6/26 cya-8 6/27 cya-7 6/29 cya-7 6/30 cya-9
    I bought a TF-100 test kit which arrived today and my test showed cya of 60
    SE Michigan
    11,969
    Yeah, you got a kit. Just in time.
    Trust YOUR reading. Your CYA is 60. Now go out and get some bleach, and shock your pool to a FC level of 24. (Refer to the CYA chart.) Use the Pool Calculator to figure out how much bleach that is.
    You will hold your pool at shock level until the FC holds overnight. There is an article in Pool School with instructions on how to do the overnight FC loss test.
    Jul 2009
    Adrain, MI
    3
    thank you and will post with results again tomorrow
    SE Michigan
