Results 1 to 16 of 16
Thread: Looking for a SWG
    Looking for a SWG
    Still in my 1st year of pool ownership, I am tired of lugging bleach to the pool. Now that I have the hang of this, I am ready to upgrade to a SWG. After reading many posts on TFP, I thought the Intex SWG would do the job. But it looks like that idea has hit a few snags.
    1) It is probably too small for my pool (25,000 gal),
    2) The manufacturer does not "recommend" it for pools with a sand filter.
    So what would work? I have the cash to install a $1000 system, but is that really necessary? I did a lot of research on this, but I don't know that I am any closer to a solution. Therefore, I submit to your superior experience and knowledge.
    Thank you in advance.
    33' Round Diamond Star AGP / Installed in 2008 / Gulf Coast, USA / Waterco Aquamite 2 HP Pump / 200 lb Sand Filter / BBB Method
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Looking for a SWG
    The only reason they would not recommend it with a sand filter is because of the routine water replacement you get with backwashing - it causes you to have to adjust your levels more often than you would with a cart filter. As long as you keep your levels in range for an SWG having a sand filter shouldn't be an issue.
    I don't know what recommendation to make on the unit itself so someone else can tackle that question.
    For a large pool like that, you should think about getting an in-ground system. Unfortunately, they do cost way more than the Intex system. Most in-ground systems are $600 to $1200.
    So how do I go about deciding which in-ground system to get? Which brand names should I avoid? And, as long as I am going Cadillac, what features are worthy in such a system?
    Thanks so much.
    Greg
    DaveNJ's Avatar
    Toms River, NJ
    520
    I have an Autopilot and quite satisfied with it. Can't comment on the other systems. I do like the manifold setup. When I run my pump on high the check valve opens, which optimizes the flow thru the cell. Appears you have a large single speed pump is why I mention it. The digital display is handy for setup and testing the system. My Autopilot is setup to control my pump run times.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    I had the Goldline Swimpure Plus installed a little over a month ago... at $800.00 plus salf and install fee, it was kinda pricy, but it's working great. No problems with my sand filter.
    18,000 gal inground vinyl pool
    25K Swimpure Plus with sand filter.
    Jul 2007
    Brisbane, Australia
    874
    whatever you choose with large single speed pump you would want to get the biggest SWG model you can afford, so you can reduce pump run time to a minimum required for adequate filtering
    if your pump run time is driven by SWG, expect high electricity bills
    KirstenHW's Avatar
    Hudson Valley, NY
    19
    I have an older 18x36 inground vinyl pool (1981) with a single speed Hayward 1HP superpump and a Hayward Perflex EC65 DE filter. No remotes, nothing fancy. I do need to reinstall a new timer for the pump - basic 2 manual-settingsper 24 hrs deal. In my case does brand matter for selecting a SWG? I am pretty handy and was wondering if installing it myself would be a big deal?
    18x36 Spartan vinyl inground ca. 1981
    1HP Hayward SuperPump & Perflex EC65 DE Filter
    Lower Hudson Valley, New York
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    nesjunk, I'm guessing you could get away with the intex swg if you are willing to run your pump 10-12 hrs. I run my pump 8hrs a day and the intex swg is on the 4hr setting. Using the suggested water balance levels here at TFP, my FC has been pretty stable between 6-7ppm and rarely do I ever have any CC, usually only after leaves attack my pool during a wind storm.
    So my thinking is since my pool is about half the volume of your you would need to double the run time...the intex swg can be set to run up to 12 hrs. You can look at some of my recent posts as I just found the intex on ebay for $145 shipped, and I actually just ordered another for when my cell on the current intex fails. We've used the intex all summer and I must say for the money it really is hard to beat, and best of all, no jugs to lug around.
    Also no worries about the sand filter...that's what I have, just make sure to adjust your salt if you've been doing a lot of backwashing.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Quote Originally Posted by KirstenHW
    Welcome neighbor Nice to see someone else from my area on TFP
    Sep 2008
    The Woodlands, Texas, USA
    243
    I got tired of lugging bleach also.
    I have had a Goldline Prologic PS8 pool controlled with integrated SWG cell now for month and love it. My costwas $1900 installed.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Sorry didnt want to start another thread . I got a 48k gallon pool its 30x40 10 foot deep end. im looking to get a SWG for it.Can somone suggest one around 12-1500$?
    DaveNJ's Avatar
    Toms River, NJ
    520
    Not an expert, it appears with that big of a pool your close the limit of a single cell SWCG systems. Autopilot SC-60 cell is rated for 50k gal. pools. Someone with more knowledge will weigh in. Might want to check out a dual cell system.
    I installed a Compupool 40k gal system. It was significantly cheaper than the name brands and works great.
    http://cgi.ebay.com/CompuPool-Pool-Salt ... 286.c0.m14
    I don't know anything about a larger system.
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by Vistal
    The SWG for my little 14K gallon IG pool is "rated" for output up to 40K gallons (Goldline Aqua Logic 15) and, if I recall the pricing, they don't give them away; nevertheless you can serially connect them to provide addtional output. If I had a 48K gallon pool I would do just that. Might be able to get two SWGs for a better price (than just 1) through a supplier.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by DaveNJ
    not even close
    single cell systems finish at around 265k gallons
    and then dedicated commercial systems with multiple cells are no different from single cell systems, you still have 1 power supply, 1 inlet and 1 outlet
