Thread: Leaking from Filter
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Leaking from Filter
    Hopefully I can get this picture to post. I have two streams of water coming down the side of the filter. Don't know if this means anything, but we recently replaced the spider gasket because I was losing a lot of water, and it was going out the backwash line. Anyway, I did have a slight leak coming down the side of the filter before we replaced the gasket, which was several weeks ago. It never totally went away. Yesterday, I noticed it was a more steady drip than before. What do we need to do?
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Leaking from Filter
    it appears to be coming from the head of the filter in the picture, have you tried tightening the screws the the collar? if you did and it still doesn't stop I would take the head off and check to make sure there isn't debris stopping the head from making a seal
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Okay, will pass this on to hubby. He says that he's tightened it as much as he can.
    Sallie
    Mar 2007
    Coastalish 'down easter'
    4,160
    Sallie, also have him check the o-ring that makes the seal - it may have been pinched, damaged or 'flattened' out preventing a positive seal.
    A small drip can be dealt with for a little while, but a steady leak should be dealt with ASAP
    When tightening the 2 bolts that retain the multi to the tank, tighten them evenly - ie., tighten 1 to be ~ 1/2" apart and then the other to be the same and then work back and forth, a few turns at a time on each side, keeping the distance between the 2 halves ~ equal while switching tightening the 2 sides, until they are fully tight. (a little convoluted explaination - but I hope you understand what I'm trying to express )
    Luv& Luk
    -Ted
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by waste
    Just say tighten it as you would the nuts on a new car wheel a little on each so that it goes on even.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
