Thread: does more gph equal more suction?
    Loogootee, IN
    122
    I have attempted to run a pump powered vacuum to no avail! I don't have a skimmer so I have been taking the hose and hooking it directly to the filter pump, of course it doesn't work.
    After trying in vane to use a vacuum powered by suction from the filter pump, I started researching my pump.
    This is what I found. It is a 30gph pump! http://www.walmart.com/catalog/product. ... d=10715079
    if the above is true, would I be able to purchase a 1,000gph intex filter pump and be able to run the vacuum?
    its not an automatic gadget, it is manual vacuum on a pole.
    Is my thinking correct? more gph = more suction?
    18ft x 48in Round Intex Ultra frame. 6,700 gallons.
    Re: does more gph equal more suction?
    Yes, the larger pump will give you more suction. Also, be sure you have one of the special low flow rate vacuum heads made for Intex pools and not a vacuum head made for an in-ground vinyl pool.
    I suspect you meant to say the 530 gph pump. Intex doesn't make a 30 gph pump.
    Loogootee, IN
    122
    Cool! I am hoping that it is just a typo on the walmart site!
    Loogootee, IN
    122
    I dunno! lol it was like 10 dollars at walmart and has brushes on the bottom of it. I have noticed the 3 closest walmarts have nothing for intex pools except their pool packages and the swg for 199
