Thread: What to do when leaving on vacation?
    Jun 2008
    Savannah, GA
    17
    I am leaving for a 8-9 days vacation.
    The SWG has been holding the FC level at 4.5 for the last week or so. I have to add acid about every 2-3 days to bring ph back to 7.6. I add at 7.8. The rest of my numbers are:
    ph 7.6
    TC 4.5
    CC 0
    TA 70
    CYA50 working to get to 70
    CH350
    salt 3400
    temp 91
    Water level is getting low and I will need to top up if we don't get rain.
    Pump runs 9:00am to 7:00pm - during sun and a little more.
    Is there anything I can do to keep the PH from topping 8.2 while I am gone? Lower it more than normal? Will a trichlor puck in the skimmer help keep it down? Any other suggestions?
    18,000 gal IG plaster Hayward S244T sand filter Pentair Challenger Pump CHII-N1-1FE
    Goldline SWG
    Polaris 280
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: What to do when leaving on vacation?
    I would lower it to 7.0 and make sure it's topped off.
    Feb 2008
    Denton, TX
    5,061
    Just a guess but since your CYA is lowish for an SWG pool, you might consider turning the SWG off and just sticking some trichlor tablets in a floater. That will keep the pH from creeping so much, add a continous source of FC, and give you a little CYA boost by itself.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You should not put pucks in the skimmer. The water becomes very acidic while the pump is off, and it can cause the skimmer parts to become brittle and break, and also wreak havoc on the pump equipment when that acidic water is forced thru the system when the pump is turned on. It's like pouring acid thru the skimmer.
    I would:
    1). Increase your CYA to 70, lower the swg output slightly. I suspect the lower CYA is causing the SWG to work harder to maintain FC levels, causing you to run it more, causing the PH to rise more frequently. With a higher CYA you should be able to run the swg less often to maintain your FC.
    2) I would lower the PH to 7.2 before you leave.
    Have someone check on your water levels while you are gone, top off if necessary.
    If you can't do these things then I would put pucks in a floater. You still would want someone to check water levels, or top it off before you go.
