Thread: cartridges filter cleaning, my first time
    I just cleaned my Clearwater cartridge filter yesterday for the first time and had a question about cleaning. When I spray the hose into it and look down inside the water coming through is murky brown. Shouldn't it be crystal clear on the inside when I am spraying through it? It has only been on the pool for 2 months. Thank you
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: cartridges filter cleaning, my first time
    it gets dirty. not sure what you're asking. clean it until it's not dirty anymore. there are some tips at this link:
    how-to-clean-a-cartridge-filter-t4465.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Nope that's normal. Keep hosing it off until you don't see gross brown water coming out of it. You won't get it super clean with just a hose, the instructions posted above will give you better results.
    Yeah I got it all clean I was just concerned that the water was coming through to the inside of the filter brown. I figured if it would go through while I was hosing it off that it would go through as it was hooked to the pool. Thought maybe my new filter was bad. Thanks
    11,969
    Are you taking it out of the filter to clean it? My instructions say to leave it in place to hose it off, but I don't, I remove it entirely so I can spray down the inside section too, and all that gunk doesn't go into the filter housing.
    Yes I take the filter out, it is dirty when I spray from the outside of the paper and look down in the hole in the center while spraying. I figured that it should be clean when I spray water through it.
