Results 1 to 11 of 11
Thread: At what point is it safe to swim after MA Shock?
    Mar 2008
    Roseville,Ca
    30
    I can't find this anywhere. Maybe I do not search well but, at what level is my chlorine safe to swim at after shocking. I am at 44 and would like to swim by Friday? Is that possible. Is there a way to "force" FC down?
    Thank You TFP in advance.
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    Re: At what point is it safe to swim after MA Shock?
    What is your CYA?
    Many of us would not hesitate to swim in FC levels up to the appropriate level for your CYA. Just wear an old suit!
    I would. however, keep very young children or pets out - who might not understand not the drink the water.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    there is a way but like mermaid said, some here swim up to shock level based on cya. do you have another thread? why were you shocking?
    but to answer your question, yes there is and they sell it at pool stores. I think it's called sodium thisfulate or something.
    http://www.lesliespool.com/browse/Home/ ... 30/I/14253
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by raiderchuck
    Refer to the CYA chart - anything below your "normal" shock level is safe. Leave the pool uncovered and it should drop rather quickly below that level. When you are at high FC levels you see a rather quick % drop as opposed to a normal 2-3 ppm. I would expect you to lose 50% of your level on a sunny day.
    We normally don't recommend shocking to mustard-algae level - and often people think they have mustard algae and they don't...
    Mar 2008
    Roseville,Ca
    30
    I shocked to 44 last night and am at 30 now.But I was on my original R087 taylor reagent last night and today had to start with the one I ordered from TFP. It says I am at 30 now.I find that impossible because I was only loosing .5 per night before that? Also the reagent doesn't look the same.It is grey and white?My cya shock level for standard algae is 23 should I just hold it there when it reaches that?Here comes the sun #$%^$^
    Mar 2008
    Roseville,Ca
    30
    Thank you about the MA shock.After sun all day I am now at 17. I am bringing back up to 23 for overnight. I checked and forgot to adjust my ph when I started.Is it okay to adjust it now.It still reads the same.
    Ph 8.0
    FC 17
    CC .5
    TA 80
    CYA 80
    CH 310
    11,969
    You should not try to adjust PH when the FC is above 10, high FC levels makes PH read a false high. If you want to make a small adjustment, to 7.8, that would be okay. I wouldn't go lower than 7.6 on your target for dosing, and risk it getting too low.
    Mar 2008
    Roseville,Ca
    30
    Thank you TFP again for all your help.Shock held overnight. Sodium Thiosulfate put in so company can swim today.
    Does the neutralizer affect any other numbers?
    Thank You
    Mar 2007
    San Rafael, CA USA
    12,082
    It might affect the pH in ways that are mysterious. Let us know what happens in your situation.
    Mar 2008
    Roseville,Ca
    30
    Did not affect anything
    Guest
    Ph 8.0
    FC 17
    CC .5
    TA 80
    CYA 80
    CH 310
    With chlorine levels that high your PH test will be off. Ignore it until you get the chlorine level back down to less than 10.
    You can then adjust your PH accurately and go back to shocking if needed.
