Thread: Higher PH during Shocking
    Jun 2007
    Kernersville, NC
    45
    Ok so i had 2 really long days of work and neglected to add bleach, so i decided to shock then get back on track. After i added 2 178 oz walmart bleach i came up with these numbers
    FC : 15
    CC: .50
    PH 8.2
    TA: 70
    Temp: 86
    Did not check cya or CH <-----was told ch was not a hugh deal on vinyl
    I have never had a single problem with my ph. But i checked it after i added the bleach. There is nothing i can do about it tonight, but will it go back down, am i getting a higher reading due to the bleach? Or should i hit Lowes first thing in the morning.
    AGP (Wil-Par): 24' round, approx 14,000 gallon, 2 hp- 2 speed cartridge filter, TF100 test kit.
    Feb 2008
    Denton, TX
    5,061
    Re: Higher PH during Shocking
    Typically, with FC levels over 10 ppm, a falsely high pH is to be expected. Recheck it when your FC falls below shock level.
    Jun 2007
    Kernersville, NC
    45
    thanks
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    While shocking your pool you will get false PH readings. Wait till it drops below 10ppm and recheck it ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
