Thread: need pebble start up help fast
    The pebble tec was acid washed today and the pool is currently filling. I decided to handle the start up myself to save a few bucks but I didn't do enough research. Anyway, now I'm scrambling to gather what I need to do this correctly. I have liquid muriatic acid, liquid chlorine, metal gone additive, test kit. I used to clean pools so I am familiar with balancing an already running pool. Any help and tips as far as quantities of acid to add initially to adjust ph, filter run times, anything would be appreciated.
    Planned build details: 16x35 freeform shotcrete, attached 7' round spa 6 jets raised 18", baja step, 3.5 to 7' depth, 4x160 pump, pentair 520 cartrige filter, mastertemp 400 heater, intellitouch 7+3 with intellichlor, autofill. Pebbletec or pebblesheen.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    Re: need pebble start up help fast
    see the new plaster article.
