Results 1 to 8 of 8
Thread: Super High CH
    May 2008
    Northern California
    73
    Super High CH
    In order to lower my salt and CH, I did a partial drain of my pool last weekend. I only drained about 15-20%. Before the drain, my CH was at 1100 (!) It was 44 drops with a 10ml sample. I assumed it was this high because I know the water in this area is rather hard. But when I tested the fill water, it was only 40. The pool is about 2.5 years old with the original fill water. Is there a logical explanation as to how the CH got so high? I never tested the CH because the store told me I didn't need to and then I found this site, so I don't know what the CH was for the first 18 months.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
    Aug 2007
    Northeastern Ohio
    178
    Re: Super High CH
    CH can get high if you use cal-hypo as your main source of chlorine.
    I would also imagine that if you lose a lot of water to evaporation, and need to top your pool off often, that would cause your CH to go up.
    I'm sure someone much more knowledgeable than I will post a better explanation.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Re: Super High CH
    robrinker listed all the likely possibilities. One, rather less likely possibility is that the fill water CH level was much higher in the past.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Super High CH
    does the new plaster have anything to do with it? besides the builder adding lots of calcium, I don't know how mine got to 625 either.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Super High CH
    Maybe the house has something that removes the calcium but the pool was filled bypassing it?
    Oct 2007
    Valrico, FL
    542
    Re: Super High CH
    It is possible that at different times of the year your water supplier used different sources of water. For example during seasons when there is abundant rainfall, my water suppliers use water from rivers and lakes. These tend to have very low CH. On the other hand during dry periods, they may use wells. Most underground water will have high CH. Normal potable water treatment will not remove CH.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Super High CH
    that's interesting. is there any documentation on that online? swiftmud's website maybe?
    Oct 2007
    Valrico, FL
    542
    Re: Super High CH
    Not really very much. It is also very area dependent. I design and built control and instrumentation systems for municipal water and wastewater plants so get to see a lot of things others don't. You might try calling your local water department.
