Results 1 to 7 of 7
Thread: Thanks For All The Info!
    Henderson, KY
    10
    I've been lurking here for a couple months now, learning a lot. You guys are really a helpful bunch of people.
    This was my 8th season opening my above ground pool. But, this time was a little different. After we closed and covered it last fall, we noticed the inner tube in the center gradually getting deeper and deeper in the pool. And, in just two weeks it was on the bottom; zero water. We had found the 3/4" little tear in the liner, right where the cove meets the floor, during the season and tried in vain to patch it underwater. We just kept adding water till we closed, fully expecting to have a new liner installed at opening time this season.
    The new liner was installed the 12th of June, but this time, I had new gladon white pool cove and a "Liner Shield" pool floor pad (lifetime puncture guarantee) installed with it. After they reworked the sand and got everything installed, this was ten times better than the initial pool install! For the first time in 8 years the bottom is flat with not one dent, wrinkle, or footprint, and comfortable on the feet. My Sta-Rite 'Lil shark actually cleans now without one hangup!
    Now to the chemicals; no more stabilized tri-chlor after 7 years of it and constant CYA problems. It's BBB for us now. And it was everybody's posts here that got me to a perfectly balanced pool.
    I had been using Borax and Baking Soda since my second season, but with trichlor tabs. I've also had my Taylor 2005 kit for the past 4 years. But, it was still that build-up of CYA that was driving me nuts. So, this season, I found this site, and now things are simple again.
    I made a big mistake after the new liner was full and I got the pump running. My PH was low, and for some reason unkwown, I added Baking Soda instead of Borax. Wow, what that did to my TA! But, no fear, using what I learned here, I quickly got all things right. I never knew of the MA method of lowering PH and aerating to bring it back up as the TA was being dropped. I have a water slide and a fountain on my return which was more than enough aeration to do the job quickly.
    So, thanks again to everyone here for all the useful information, pool school, etc. I can relax now. I'm running my pump on a 6hr on/ 6hr off cycle getting 12 hrs circulation per day,adding bleach at start of each night 6 hr cycle.
    GREAT SITE!
    My numbers this morning were:
    Temp: 90
    FC: 3.0
    TC: 3.0
    TA: 100
    PH: 7.6
    CH: 210
    CYA: 40
    Jerry
    24' X 52" Vogue Impact AGP - 13,500 gal. (Installed 2001) - Jacuzzi Laser 225 sand filter w/7 way valve, 1-1/2 hp pump - "The Step" single center rail steps - "Zoomerang" deck mounted AG slide w/adjustable water flow - "Aqualuminator" return fitting pool light w/fountain attachment
    Taylor 2005 Test Kit w/add-on FAS chlorine test kit
    Re: Thanks For All The Info!
    Welcome to TFP!
    Sounds like you got a handle on your water without even having to ask a SINGLE question!!
    Post some pics later!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Hi jwsr and welcome to the forum
    Very, very nice post
    Yep, we'd like to see some pix
    You're done SLAMing when:
    Arizona
    924
    Sounds like you've got it all under control. Good job!
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Henderson, KY
    10
    As you requested.......... a pic. Only have one that I took of the new liner for now. (before we put the steps back in) I'll get some wide angle shots showing the deck I built, the landscaping, and pump/filter set-up later.
    Jerry
    Butterfly's Avatar
    South Carolina
    10,045
    Wow! Looks great!
    Now we're waiting on the wide angle shots
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    WOW. Crystal!
