Thread: PH Rise
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    PH Rise
    I have a 12,000 gallon SWG pool with an attached spa. The spa is higher than the rest of my pool and has a large 6 foot curved section of stair-steps stones that lead to the main pool. There is also a fountain in the spa that is always on. When my pool is running the water runs over the stair-steps and into my pool, so I have aeration going on all the time. My pH is always going up...after reading this forum I believe the aeration has allot to do with it. Will keeping my TA low (60 - 80) and adding borates help me keep my pH in-line??
    I had been keeping my TA in the 100-120 range but I'm working to get it down in the hopes that this will help my pH problems.
    Master KomodoKamado griller & beer maker!!
    12,000 gallon in-ground, pebble-tec, SWG pool w/spa
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: PH Rise
    yes it will...aim for a ta of 70 with the constant aeration and swg...if that's not enough, you can go as low as 60
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH Rise
    Hey bbqbrew,
    Yes, adding borates will help with pH stability.
    Have you seen the SWG Water Balance TIPs in Pool School?
    Welcome to the forum
    You're done SLAMing when:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: PH Rise
    My apologies...didn't notice this was your 1st post...welcome to TFP!!!
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    Re: PH Rise
    Thanks for all the info! I will post my full test results and see what everyone thinks of my numbers.
