Thread: Determining Pump Flow Rate
    Vero Beach, FL
    462
    I am having a pool built right now. It has an attached spa. When I fill the pool / spa, I can determine the exact gallons of the spa by measuring how long it takes to fill and knowing the gpm from my hose. Later, can I then drain the spa, fill it with the pump making sure it is sucking from the pool drain and returning only to the spa and be able to figure out the pump gpm? I know the head might be slightly off, but do you think it will be close enough?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Determining Pump Flow Rate
    That should give you a rough idea but it could be more than 10% off depending on the difference between the pool and spa plumbing. However, you could probably make adjustments based upon the difference in filter pressure.
    Mark
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
