Results 1 to 7 of 7
Thread: Green in little glass "jar"
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    My pool looks great, and all my test levels are great. However, the little glass "jar" that is connected to the backwash gets dark green fairly quickly. I backwashed a week ago, and just added CYA a few days ago, so I can't backwash again for a few days. Why does that little glass jar get green so quickly ? And do you backwash as soon as it does? (mine starts turning green after only a day or 2)
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    Re: Green in little glass "jar"
    Did you put the CYA directly into your skimmer, so it immediately went into the filter??
    If you put it in a sock, you CAN backwash.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    It sounds like you are talking about the backwash sight glass. Water runs through that glass when you are backwashing so you can tell when you are done backwashing. The water will turn clear when you are done. When the system is left in filter mode, no water is running through there. Given some sunlight, algae could grow inside. That doesn't really matter, it will all get washed out the next time you backwash.
    You want to backwash when the filter pressure goes up by about 6 psi over the pressure when the filter is clean.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Happens to my sight glass too. You can turn off the pump and unscrew the glass from the filter. Clean it, put it back on.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    May 2009
    Dallas, TX
    62
    Thanks, it is the sightglass for backwash. As long as it's okay that there's algae in there, I won't worry about it.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hate to tell you this but... if it gets greener as you start to backwash - you've got algae in the filter (and, unfortunately, it looks like it's alive and growing -- or this is your first backwash after cleaning up a pond of a pool) It may well be best to take the filter apart and hose it of thoroughly (every square inch of the grids!).
    If you haven't already please feel free to read Use and Care for DE Filters
    Luv& Luk
    -Ted
    May 2009
    Dallas, TX
    62
    We cleaned the filter about a month ago. After I backwash, the sightglass is clear, but after just a day or 2 the water in the sightglass starts to turn green. I think it's probably because it's sitting in the sun, and algae is just growing in the sightglass.
