Results 1 to 8 of 8
Thread: using a lot of chlorine during the day
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Hi everyone. My pool has never looked better since my conversion, but I seem to be using an awful lot of bleach to keep my levels up. I did the overnight test and everything was fine, but seem to lose about 4 ppm's during the day when it's sunny. This is requiring me to use about 3 quarts of bleach a night to keep at recommended levels.
    Just for fun I tested yesterday in the morning. It was cloudy all day and I tested again in the evening, only lost 2 ppm's. FC level was 6, bumped it up to nine overnite.
    Tested again this morning, was still at 9. Was sunny all day, just tested again for the evening and sure enough back down to 5, added another 3 quarts to allow for burnoff tomorrow.
    Does this seem like a lot of bleach or is this normal? I've read where some only have to add a cup or two a night and I'm having to add quarts. Going through a few gallons a week at this rate.
    My numbers are:
    FC 9 (can almost garauntee it will be back to 5 by tomorrow evening)
    CC0
    TC 9
    PH 7.8
    TA 120
    CYA 50
    Any recommendations will be greatly appriciated. Thanks!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    30,414
    Re: using a lot of chlorine during the day
    Yeah, 4ppm daily loss is a little higher than average but not earthshaking.
    Remember that only two things reduce the FC in your pool. Sunlight and organics.
    Is your pool really active with a heavy swimmer load?
    How much Sun do you get daily?
    Lot of kids in the pool?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Sounds normal.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by pepsiholic
    They have smaller pools, therefore less bleach.
    You're done SLAMing when:
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    I am using about 3 quarts a day as well. I was told to raise my CYA to 50 (from 25). Do you get a lot of sunlight? If so, you might consider bumping up your CYA to 60 or 70.
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Thanks for the replies everyone, good to know I'm on the right track.
    My pool does get full sun everyday, all day, although I don't have a large swimmer load (unless you count all of the japenese beetles I've been skimming out constantly...lol) . Maybe every couple of days my daughter will have a friend over, but it really doesn't get used much until the weekend.
    It's still cheaper than the baquacil, I was using, so I guess I shouldn't be complaining..lol...just need to get back to walmart and stock back up. I was there the other day and all the big jugs were gone.
    May 2009
    Charlotte, NC
    12
    I had similar consumption before I got the solar cover. I now use about 3 qts (about 3.1 ppm) every other day with swimming and CL target levels between 4-7, CYA 40. I have full sunshine and lots of trees, bugs etc., but I lose the most chlorine between 11.00am and 4.00pm
    Above Ground 14.2 K Gallon, vinyl, Baquapure sand filter, 2.5 HP pump, K-2006 test kit
    11,969
    Yes, a solar cover during the day when the pool is not in use definitely reduces uv loss. Esp. the darkblue/black ones.
