Results 1 to 19 of 19
Thread: What do you use to measure liquid chemicals?
    Tonedeaf's Avatar
    Jun 2008
    East of Dallas
    104
    What does everyone use to measure out their chlorine or muriatic acid??
    14100 gallon IG Gunite Pool
    Sapphire Smoke Quartz Plaster
    Pentair SunTouch Controller, Intelliflo 4x160 Pump, 520 Cartridge Filter, Intellichlor SWG System
    Legend Platinum Cleaner with booster pump
    My Pool Build
    22,553
    Re: What do you use to measure liquid chemicals?
    I use a nice graduated Rubbermaid pitcher for both. I'm careful to rinse it out before each use and drain the water out before i put the chemicals in it.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I got a plastic measuring cup from walmart. holds 3 cups I believe.
    Feb 2008
    Denton, TX
    5,061
    Same. Plastic measuring cup.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I use a Pyrex 8 oz cup for small amounts like HCl, a 2 qt plastic pitcher for chlorine, and a 2 cup scoop for dry chemicals.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Pyrex 1 quart measuring cup.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Apr 2008
    Central Texas
    326
    97 cent plastic kitchen measuring cup from Walmart here.
    Pyrex (or any glass) near the pool is not a good idea. If you drop and break it, the slivers that land in the pool will instantly disappear. At least until they stab into someones foot.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Oct 2007
    Cedar Hill, TN
    252
    One of the empty bleach bottles.
    I cut out the material under the handle to make a large opening. Black magic marker was used to mark the fill line at 3 cups, 6 cups and 9 cups.
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Jan 2009
    Cupertino, CA
    1,966
    A plastic measuring cup, 1-cup total. But I use 12.5% so it's not so many cups at once.
    --paulr
    BBB "Intermediate Swimmer"
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    Quart sized pyrex measuring cup. However, after reading all these comments, I think I'll switch to an old bleach container with sharpie markings. I miss my pyrex in the kitchen, and would hate it if it broke poolside.
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    Arizona
    924
    I use a quart cottage cheese carton with Sharpie markings at every cup level.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jun 2007
    Arlington, VA
    29
    Nothing. I guess! Pretty good at it by this point.
    ____________
    34,000 gallon pool with charcoal Marquis aggregate finish
    Jandy stealth pump, cartridge filter and Aquapure SWG
    Solar heating with Goldline controller
    Polaris 380 Blackmax
    4 cup plastic measuring cup. Rinse well and store it near the pool.
    Jul 2007
    Rockville, CA
    99
    For adding muriatic acid, I use a plastic measuring cylinder from Pampered Chef. It has two parts. The inner cylinder has a pour spout and is made of thick plastic similar to the material from which a muriatic acid bottle is made. The external sleeve is non-slip clear plastic with both wet and dry measured markings.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    sammm's Avatar
    North Richland Hills, TX
    257
    Plastic paint-mixing cup (with marked graduations) I picked up at my local Big Box store.
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    Plastic 1qt measuring cup
    2003 Marquis Euphoria - 400gal
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I use a plastic 32 oz plastic measuring cup I got at Target I believe. I liked it because it had a nice poring spout and graduated easy to read.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    I need to get me one of these measuring cups everyone has. Today I have a bucket that was originally frozen Margarita mix with sharpie marks for quarts. I just do the math for number of cups in a quart. Measured the marks using a plastic Rubber-made tea pitcher with tap water.
    27' round AG vinyl, 54" height with 18,200 gallons of water.
    1HP pump, 150lb sand filter run 12-14 per day. Using 12.5% liquid chlorine. BBB method.
    Taylor K-2006 test kit. Lamotte strips for borate at 50ppm.
    Goals: CYA-40, TA-80, FC-4, CC-0, Borate-50, PH-7.4-7.8 with use of fountain.
    Henderson, KY
    10
    32 oz. Pyrex measuring cup, handled carefully.
    Jerry
    24' X 52" Vogue Impact AGP - 13,500 gal. (Installed 2001) - Jacuzzi Laser 225 sand filter w/7 way valve, 1-1/2 hp pump - "The Step" single center rail steps - "Zoomerang" deck mounted AG slide w/adjustable water flow - "Aqualuminator" return fitting pool light w/fountain attachment
    Taylor 2005 Test Kit w/add-on FAS chlorine test kit
