Thread: Pool Pump stops working, very hot, now working again
    Jun 2007
    Atlanta, GA
    My pool pump stopped working today. It just stopped. The case was very hot. So I turned it off, left it for an hour, and turned it back on. It's still hot, but it was running normally. The only thing I can think of is that the solar panel valve is automatic, and turns on and off based on the Jandy controls. Maybe it turned on and the pump could not force the air out of the solar panels. The pump is a StaRite 1.5 HP. I is probably 4-5 years old. As it just so happens, today is the first day I ran the pump for a constant 9 hours instead of 2 different 3 hour shifts. However, I have run this pump continuously for 24 hours, as recently as 3 days ago, without any problem (that I know of). Any thoughts about what to watch out for? Does this mean my pump is going?
    Pool: 15,000 gallon 32'x18', 3'-6' deep in-ground gunite pool, Sta-Rite 3 125 GPM 2-filter cartrige, 1.5 HP Sta-Rite pump, solar heater, Goldline SWG, Jandy controls, opaque automatic CoverStar solar pool cover, 3 waterfalls (not from spa).
    Spa: 485 gallon in-ground square acrylic over fiberglass suspended over gunite Sunset brand spa, isolated system, natural gas heater, 2-speed (4hp/11hp) main pump, 3hp booster pump, chlorine sanitized.
    To my pool store owner, nothing is more important than my pool and my money.
    Richard's PoolEquations Spreadsheet
    The two most likely possibilities are that either the water flow was blocked or something is going wrong with your motor. Checking water flow is easy enough. If the pump was in direct sunlight while running it might have gotten to hot that way, though that would have to assume that you had not had much direct sunlight while it was running in the past.
