Thread: help! how to fit vacuum hose to skimmer basket?
    I bought a clearview vacuum head and vacuum hose but the head doesnt fit my intex telescopic pole. The vacuum hose also doesnt fit in my skimmer basket. I have tried putting it from the top and the bottom but both holes doesnt fit. Even if it does fit, I wouldnt want the debris to go directly into the filter. Do I need a different skimmer? a skimmer vacuum plate? I dont know what to do!
    Intex Ultra Frame Metal ABG Pool 16' round x 48"
    4000gph intex filter pump hooked up to 1500gph filter pump to solar bear 4'x20" solar panel to
    intex swg to pool
    deluxe intex maintenance kit, clearview vacuum head, tf100 test kit
    MikeInTN's Avatar
    Middle Tennessee
    Re: help! how to fit vacuum hose to skimmer basket?
    What type of skimmer do you have? If I plug the vacuum hose directly into my skimmer, I have to use a conical adapter (the adapter actually came with my Aqua Bug cleaner).
    Depending on your skimmer, you might be able to find a vacuum plate for it. Also, if your skimmer has a basket, you can use a skimmer sock to catch the stuff before it goes to your filter. Lots of ifs, all dependent on your skimmer.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
