Thread: Please help!!
    Please help!!
    A friend of mine is having so many problems with her pool. I told her that I would ask for help. She had algae, black algea, and, in my opinion ,mustard algae. On Friday night she completely drained her pool. She power washed everything. She was told by several "pool people" to do this. She has filled har pool back up and her chemical are haywire. Her latest results are..,.FC 0, PH 8.0, TA 170, Calcium Hardness 180, CYA 0. She has already added 5 lbs of shock and uses the tablets. she has added 2 pounds of stabilizer and 2 cups of acid. I do not know what to tell her to do at this point. This forum helped me greatly get up and running a couple of years ago and my water is beatiful. I told her never fear there is plenty of help here.
    Thank you,
    Shannon
    I know it is an 18000 gallon pool. DE Filter. She is single and does not know anymore than that.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Please help!!
    she needs to read pool-school/ and start using bleach/chlorine. muruatc acid to get the ph down is also advisable (can be found at pool stores or hardware stores).
    Feb 2008
    Denton, TX
    5,061
    Re: Please help!!
    Yep, what reebok said. Also, is she using your test kit or her own?
    22,550
    Re: Please help!!
    She should be running her pump 24hrs a day.
    I can't get the pool calculator site to work right now but you should go there and plug in the numbers and see what it tells you to add. Then you can tell her what she needs to do.
    Finally got the calc to work.
    Here's what it says she needs to add based on the numbers you gave.
    Add 1-3/4 gal of bleach.
    Add 37 oz (1qt + 1 cup) of 31.45% Muratic acid.
    Add 6-1/2 lbs of Cyanuric Acid.
    That should get her started.
    I'd test the CYA again before adding anything because it takes it a while to dissolve and mix and she's already added some.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Please help!!
    This is a brand-new fill so the starting CYA is 0. She already put in 2lb so she wants about another 4lb (for 6 total). But don't bother testing CYA until a week after the last of it goes in.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Please help!!
    Quote Originally Posted by shannonij
    Thank you,
    Shannon
    Does she have access to the computer - so she can read Pool School and use the Pool Calc herself?
    What kind of pool is it, plaster or vinyl?
    Did she use Dichlor shock or Cal-hypo shock?
    The tablets will help keep the PH/TA to go lower, but she will need to stop using them eventually.
    If the shock was Dichlor, and she added 2 lbs of stablizer, her CYA is probably already in the 30 range by now.
    Is there any residual algae left? She'll still need to shock until the FC holds overnight, running the filter 24/7.
    The best thing you can do for your friend is have her join the site (if she has computer access) so she can learn for herself.
